Real GPS verses Phone GPS
Printable View
  • 12-09-2012
    GlazedHam
    I've been using an Android and iPhone 3 to record my rides and then upload to Strava. There is a really twisty loop nearby that is generally considered to be 11 miles when measure via traditional wheelbase cycling computers. Both of the phones put it as just over 10 miles. My assumption is that the GPS sampling is just too infrequent or inaccurate.
    Will a real GPS work better? If so I may get one of the Garmin Cycling Computers otherwise I may get a Garmen eTrex 20 to be used for bikepacking, etc and keep using the iPhone for rides under 5 hours (max iphone battery time in my experience)
  • 12-09-2012
    Harold
    better than the phone, not as good as a wheel sensor. on the plus side, most of the cycling units (and quite a few of the newer handhelds that are ANT+ compatible) can use a wheel sensor.
  • 12-10-2012
    ziscwg
    I think if you are on the bike more than once a week, the dedicated GPS is the way to go. It offers many features and does most of them really well.
    My Garmin 800 is just turn it on and ride. I locks sats in under 30 seconds in a new area. I can't tell you how many times I've heard from my buddies, "Humm, I guess I was not locked on at the begining of the ride" or "i guess I lost reception through there"
  • 12-10-2012
    OldMTBfreak
    GPS only updates once a second, the lag through the phone makes errors (phone polls repeater; repeater tells phone the coordinates). We (maybe me?) ride around 20 ft/sec, so all those little errors are turned into bigger errors. Oh BTW, the team I worked with spent 6 billion of your tax dollars on the GPS system. Use it proudly; and smile:D.
  • 12-11-2012
    fishbum
    Huh? The phone doesn't get coordinates from any repeater, the phone receives the same GPS satellite signals that a handheld GPS does, and calculates the position once a second.
    You are confusing GPS reception with 'cell tower triangulation' which is not accurate at all, using the cellular signal strength and delay to approximate a position (not GPS signals).
    The only other thing that Cel towers sometimes do is provide 'assistance' to the phone GPS receiver (A-GPS) by providing some of the satellite data directly to the phone via a cellular connection instead of waiting 30 seconds to download that same packet of data from the GPS sats.
    The general reason that phones perform poorly with GPS is that their antennas are generally not optimized for GPS, instead they often have a multi-band antenna (which doesn't do any band really well), or if they do have a dedicated GPS antenna they don't have a sufficient ground plane to be highly sensitive and accurate in challenging reception conditions, like a dedicated handheld GPS can.
  • 12-11-2012
    edubfromktown
    Phone GPS is good enough for me in the Mid Atlantic region and also worked well enough on the outskirts of places like Cortez, CO, Red Lodge, MT, Moab, UT, Jackson Hole, WY, etc. Not as accurate as a Garmin however carrying a single device is preferable for my minimalist needs.
    I use Cyclemeter on iPhone 5 (log to dailymile and less often to ridewithgps) and log 3-4 rides per week. Compared to the peeps with wheel sensors, my mileage is off by ~8% and the ride maps are good enough for my purposes.
  • 12-14-2012
    shagster
    I got annoyed by the inconsistencies of the phone based apps (I used android and iphone versions). I was riding along side a friend with a Garmin GPS and coparing each ride on Strava and it was silly how different they were. I ended up buying a Garmin Edge as soon as I could afford it.
    It seems that the GPS does not update frequently enough on the phones, however, the iphone was much more accurate in ideal situations (weather) than the android version.
  • 12-18-2012
    runpeterson
    If money allows, better Real GPS
  • 12-19-2012
    Gundam168
    I'm using Everytrail app on a Motorola Defy+ Android 2.3 phone. The Endomondo app I used before locks in quicker (<20 secs) but it doesn't have the camera function of Everytrail where you can take photos along the track. My only gripe with the phone based GPS is when I go through a highly urbanized area surrounded by 20 storey plus buildings, the tracking gets handed to the nearest cellsite which looks like I suddenly flew like Superman across a building faster than a speeding bullet. Otherwise, I'm happy with the GPS enabled camera function of the Everytrail app.
  • 12-19-2012
    fishbum
    ...highly urbanized area surrounded by 20 storey plus buildings, the tracking gets handed to the nearest cellsite...
    Not exactly - the GPS does not derive a position from the cel tower. What you are experiencing is multipath reception where the GPS signals bounce all around the building surfaces and the GPS has a hard time differentiating between the real (direct) signal and the same signal arriving later because it is being reflected by all those large surfaces. A good GPS has a multipath algorithm that can choose the real signal and reject the delayed signal.
    Remember, the fundamental principle that GPS works on is speed of light to determine distances, so if the GPS picks the wrong signal (delayed) to use for the solution then the position can be way off...
  • 12-19-2012
    JoePAz
    I am not sure how this happened, but I am using my blackberry and GPSLogger to record my rides an upload to Strava. One day I was riding down to a museum with my father in law. I turned on the GPS to log the ride mostly to show him where went etc. So we ride to the building and I forgot to turn off the GPS logging as we went inside. I had it in my camelbak and inside the building it actually tracked all my movements. I only noticed this later when I down loaded the ride. So I was getting GPS signals inside building. From what I know about GPS this should not work as GPS is line of sight so I can only assume it was cell tower assisted at that point. I would not say the track it left was inch perfect, but it did correlate with my general path surprisingly well.
  • 12-19-2012
    Harold
    the gps sat signal can penetrate some buildings sometimes.
  • 12-19-2012
    Gundam168
    Thanks for the clarif...Does that happen to a "real" GPS device like Garmin?
  • 12-19-2012
    Harold
    it can, but dedicated GPS receivers are better able to process multipath signals. basically, what you see on your cell phone GPS is similar to where dedicated GPS receivers were 10yrs ago. Sensitivity is better, so you aren't going to drop the signal as much, but the accuracy is pretty similar.
    What's worse about the accuracy issue is that there's quite a lot of variability from one phone to another, and also quite a lot of variability from one app to another (every app processes the raw GPS data from the phone in some way or another, but they don't all do it the same way) so it's really hard to say with any certainty what phone/app combos are going to produce the most accurate, most consistent results. plus, when it comes to phones, you can buy an external bluetooth GPS receiver and improve the GPS performance of all of the apps on your phone because you are bypassing the lower quality integrated GPS hardware with a better quality GPS antenna and chip.
  • 12-19-2012
    Gundam168
    Thanks for the info. That;s why I noticed, that tracking seems better (more close to the road) on my cheaper Huawei Ideos U8150 (600 MHz) than on my Motorola Defy+ (1GHz) using the same app. I hope smartphone manufacturers could show measurable info on what GPS hardware they use so as customers can make an informed choice.
    So that's why even if my GPS smartphone is in my pocket or even inside my scooter's compartment, it can still pick up GPS signals and continue tracking.
  • 12-20-2012
    broadwayline
    I used my iPhone 3gs then 4s for mapping for a long time, then switched to an edge 500 garmin as i had problems with the signal dropping out in valleys leading to weird results on certain trails
    edge 500 completely fixed the issue (with no wheel sensor) and I have never had a problem since on any trail
  • 12-20-2012
    dirtdan
    I use my iPhone (each newer released model seems to be more accurate than the previous one) and am currently just on the iPhone 4. I find it works extremely well. In 4,000 miles of riding this year I can only remember two rides where I had to manually edit a few GPS data points to get the correct ride.
    With the money to spend, I would go with a dedicated GPS for sure and would expect better results (as has been reported by most users) but I'm quite happy with my setup.
    I use MotionX and have found that different applications have better bad GPS point filtering than others and MotionX seems to put out some good GPS data compared to my experience with endomondo, strava and everytrail.
  • 12-21-2012
    nonamed
    I stick to my SGSIII but soon gonna buy real standalone GPS device from Garmin . Much better choice than any phone with gps built in .
  • 12-21-2012
    SV11
    The most important aspect of a gps is the chipset. I think the latest and greatest chipset is SiRFstarV. Earlier chipsets would drop out a lot, especially if your in a city surrounded by buildings. The latest chipset will be more accurate and determine locations a lot quicker. The good thing about SSV is that it uses cell towers for WiFi signals, which in turn leads to better satellite reception when surrounded by buildings.
  • 12-21-2012
    AZG23
    This..on both MTB and ROAD rides, the Droid X2 would skip all over the place putting a real damper on the end of my rides to see it would cut off anywhere from 5-30 miles at times.:madman:
    I gotta early xmas gift from the wife..a Garmin Edge 500 and K-Edge mount..first ride today with was a 66 mile/5,000 foot elevation road ride on my Tarmac in the boonies/canyons to a lake and it recorded perfectly. No skips...no issues...PERFECT!
    Ive seen the iPhone work well to record, and my buddys' Galaxy S3 works well too...but my luck was hit and miss..I'm a def believer in a dedicated GPS..
  • 12-22-2012
    Harold
    It doesn't get the wifi signals from cell towers, it can use wifi OR cell towers to augment GPS (it receives GPS, GLONASS, Galileo, and Compass sat signals).
    Next-gen SiRFstar chips go beyond GPS for positioning - GPS
  • 12-23-2012
    Muffinhead
    Another thing to consider is whether you have a nice phone or not. If you wipe out, it's safe to say that a bike specific GPS will have a better chance of survival than an iPhone. Plus, these bike computers also have a plethora of other functions that a phone doesn't like temperature.
  • 12-23-2012
    Gundam168
    A plethora of temperature functions.
  • 12-23-2012
    Muffinhead
    You can also add maps, your riding route, track your elevation, measure your heart rate, train towards goals, and check the pressure. In addition, phones don't work in the same range of operating temperatures as bike computers. The battery life is also longer than a phone. It just makes more sense to me to get a bike GPS rather than use a phone.
  • 12-23-2012
    Gundam168
    I can play my dying elk ringtone on my smartphone and leave it on a tree to distract the bear chasing me.
  • 12-24-2012
    Muffinhead
    Lol. I'm not saying in any way that a phone can't get the job done. But as someone else said, if you have the money, a gps is the way to go. But ultimately if a phone used as a gps does what you want, then go for it.
  • 12-24-2012
    Mordock
    Lately I've been using my Samsung Epic paired to a GPS Bluetooth logger/receiver (Qstarz BT-Q1000XT) with Endomondo. It is much more accurate than the the GPS on the phone. It is able to lock on more satellites and update faster. A plus side of that, my Endomondo readings are longer in distance like they should be. Plus, if my phone fails or runs out of battery, I can still pull the log from the GPS unit and upload it manually. The only function that doesn't work is the auto pause in Endomondo which sucked anyways, so I just use a external headset button to pause it if needed.
  • 12-29-2012
    GlazedHam
    I wound up getting an Oregon 450. Thanks for all the help guys.
    edit: $199 US
  • 01-08-2013
    Nazgul350r
    DCRAINMAKER Reviews
    2011-sport-device-gps-accuracy-in-depth.html
    2011-sport-device-gps-accuracy-in-depth_09.html
    Here is a very in depth review of some of the popular running watches vs the iPhone4. The Garmin Edge 800 is in there as well.
  • 02-03-2013
    t51rmkiv
    edit: $199 US
    Where did you find that deal?
  • 02-07-2013
    FMCurto
    As far as I know dedicated GPS units cant show more than 1 trail at a time or if they doits overly complicated to prepare.A file like this would render an error in GPS devices or "printed" on screen very weird:
    (its a GPX with most available MTB tracks at a given area)
    Attachment 769393
    Of course you cant navigate trought a file like that but I think the advantages of having it printed on GPS screen are obvious, more so if you are unfamiliar with the area.
    Until recently all available software I knew had the same problems, but the maker of Trekbuddy (Kruch), a FREE java GPS custom map aplication that works on any phone (except iphone and windows mobile I think) was so kind as to introduce a new feature I havent seen anywhere else allowing to plot as an overlay a file with multiple tracks. If you're exploring an unknown area you can "print" on screen multiple alternative paths to the "printed" route and decide on the field wich ones to take.
    Its still in beta version but workable, current version (1.6) doesnt have that feature but next ones will:
    TrekBuddy - Outdoor companion
    The phone real handicap for me was battery life, that was until I purchased an external 7k mA USB portable charger/battery that is about the same size as the phone.
  • 02-07-2013
    Flyin_W
    Re: Real GPS verses Phone GPS
    Muwahahaha..
    Now seeking Honey Badger ringtone.
    Already carry so much in my pack that it entertains people. Use an Android phone GPS with MyTracks, and get very good results with by running it in Airplane Mode.
    Doing this saves battery life, good all day, eliminates cell tower triangulation, unwelcome calls, and it works reliably under heavy tree cover.
    Try this ^ before you give up & buy another item to stuff in your pack. And yeah, I crash far too often to mount anything on the bike..
  • 02-28-2013
    n64kps
    Actually most high end smartphones these days come with a ton of sensors that record Strava data comparably to a Garmin (or similar). The phones use a combination of Wifi, cell towers, GPS, accelerometer, gyroscope, barometer, and compass to gather data for Strava ride recording. I'd considered running a standalone GPS instead of my phone but the only benefit I see is longer battery life and current speed readings. Using a RokForm case/bike mount, I just put my phone on my steer tube and I'm off!
  • 02-28-2013
    Harold
    you're a little mistaken there. GPS apps use the GPS antenna. I dunno if you've ever used wifi-only location finding but it usually can't even put you on the correct side of the street. while the phone can do it and apps will use that location if there's nothing better, if you have a gps signal, it's not useful. cell towers are only used to download ephemeris (tells the GPS which satellites to look for) which speeds signal lock. your phone cannot determine its location with cell towers alone, hence the Assisted in AGPS. the accelerometer is not used with GPS apps. neither is the gyro. the compass is not used for data recording, either.
  • 03-01-2013
    rave81
    what do you think about the suunto quest with gps pod?
  • 03-09-2013
    dnoyeb
    That is incorrect for the question that is being asked. On android, Google maps for example, if the GPS signal is lost, the cell tower based location will be passed to the application. This happens automatically and will make your application look like you just jumped from where you are to right under the cell tower.
    This can be disabled but it will then continue to harass you to reactivate it. The application is not getting a confused GPS position, its getting a cell tower position automatically when GPS position is lost.
    When I use endomondo I must turn this off or it won't even begin to track right. At least that is how endomondo worked a year ago.
  • 03-13-2013
    Joe@MBD.com
    I used the Strava app on my Droid (on the Palm Canyon Epic) while my buddy used his Garmin Edge 800. The distances measured by each device were within a mile (25 mile ride). The elevation gained were waaaaaaaaaay different (a couple thousand feet). Since the phone has no accurate way to measure altitude (Garmin uses a barometric sensor) I am pretty sure the 800 reading was more accurate.
