Results 1 to 9 of 9
    Reputation: littlebadboy's Avatar
    Mar 2012
    Question on wheel size setting on bike computer
    When I set the wheel size setting on bike computer for the wheel size factor, should it be the diameter of the wheel only or wheel + tire?
    Reputation: dirtdan's Avatar
    Outer diameter of tire on wheel. Some people using chalk on the tire, roll it and measure the distance from chalk to chalk as it leaves the chalk imprint on the floor.
    Mar 2012
    Quote Originally Posted by danhasdrums View Post
    Thanks! But you can actually just multiply the diameter by pi=3.14159265.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by littlebadboy View Post
    Most computers use the rolling circumference of the tire in mm or cm for the calibration number
    mtbtires.com
    Dec 1998
    It is easier to do a roll out than get an accurate diameter measurement.
    mtbtires.com
    Mar 2012
    Quote Originally Posted by shiggy View Post
    It's just a matter of unit conversion.
    I wonder if the difference matters... I'll try to experiment on that.
    My 2.2 inch Continentals have a larger outer diameter than my 2.35 Nevegals so I've come to the conclusion that those numbers aren't very accurate. Plus you'll have a different in outer diameter based on the width of the rim. A wider rim will create a larger outer diamater as well. The numbers on the tires aren't very scientific.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    AZ
    AZ is offline
