Results 1 to 6 of 6
    bc3
    bc3 is offline
    Problem loading courses on Edge 305
    When I attempt to "Send to Device" in the Training Center I get the folloing message: "Your workouts were successfully sent to your device. There was a problem sending the courses." None of the courses I have in the TC appear in the courses region of my unit.
    Any suggestions?
    I have searched the forum and ensured I have the latest software/drivers.
    trail rat
    Reputation: slocaus's Avatar
    Quote Originally Posted by bc3
    Any suggestions?
    Make sure you are on the History screen and not the courses screen or it errors, at least it does for me.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    bc3
    bc3 is offline
    Thanks for the suggestion but...
    it didn't work. I guess I'll try Garmin support.
    I am still having the same problem. Garmin CS isnt helpful, she had me reset, etc all to no avail. what os do u use? Basically i think we will need to wait for the SC to be corrected. I dont believe its a unit problem. At any rate, for me, if i keep txfring eventually i get it to work
    Reputation: dnoyeb's Avatar
    Recreate the course and try again.
    I had the same problem with my 305. I deleted all courses from the garmin and from TC software. Recreated course in TC, then sent them to garmin device, worked fine then.
