Results 1 to 3 of 3
Thread: Oregon 450 ??
    Reputation: MikeBurnsie's Avatar
    Jan 2011
    Oregon 450 ??
    I have an Oregon 450 I use to map trails I've ridden. I have no problem uploading to Garmin Connect when the track is "current", a new activity it's called. My ? is can I upload tracks from my archive? I don't see any option to do that when I interface my GPS with GC. Any help would be appreciated, Mike
    2016 Transition Patrol
    2011 Stump Jumper
    2018 NukeProof Scout
    Go to manual upload. Then select the file from Garmin -> GPX
    since 4/10/2009
    Reputation: Harold's Avatar
    you probably have to do more if your ride was longer. the auto archive stops at 2000 track points. many times I have to download it to my computer, merge multiple archive files together, and then save it before uploading.
    you should be saving your rides to your hard drive anyway, if you want a saved record of your stuff, because history tells us that websites will lose stuff from time to time.
