Results 1 to 8 of 8
    Mar 2013
    Is my HRM defective?
    My HRM (Cateye CC-RD420DW) will appear to be working correctly then all of a sudden say my heart rate is 60-70, then 150, then settle back at 120-130. I also find it odd that it never goes above 150 even when I am DYING. Is my strap in the wrong spot? Is it defective? I have the sensor just under my left pec.
    since 4/10/2009
    Reputation: Harold's Avatar
    At the time this happens, are you pre-workout (dry) standing still, well into a workout and dripping sweat but otherwise standing still, moving with jersey flapping, are you in a specific location (like near high tension lines) or what? What are the exact circumstances when this occurs?
    Do you use a HRM conductor gel?
    How old are you? What is your calculated max HR?
    Mar 2013
    28, 185-196 depending on formula, no gel
    While training. Only used it twice so both times were cold, but still sweating a little. It has happened in the middle of nowhere and in town--seemingly random.
    since 4/10/2009
    The standard recommendations apply here. First, try a baselayer between jersey and strap. Also get some HRM contact gel (drug store product).
    Also, many HRMs have wacky readings when one or both of the batteries starts getting low. But especially the one in the strap. Even if it's new, the battery could be low depending on how long it sat on a shelf before it became yours.
    Jun 2010
    Hi,
    I have exactly the same problem but it seems to be on the regular basis. It is garmin hrm and edge 500. Sometimes it goes to correct reading, but most of the time it is incorrect.
    I have been using edge 500 for more then four years and it is my second hrm. I have replaced the battery and putting some moisture on sensors before riding.
    Problem appeared 2-3 weeks ago, before it was ok.
    Should I consider getting a new hrm, or it is a problem with edge?
    Ride More, Work Less
    Reputation: heyyall's Avatar
    I just give mine a big lick right before starting. That has always worked. If the battery is fresh, I would try washing the strap and then using either gel or a big lick.
    Craigslist & MTBR --free ads for all
    Jun 2010
    seems to be an issue with strap. I coupled strap from my first HRM with a transmitter unit from second HRM. Today it worked well.
    However, there are lots of threads on this subject in google and in 90% of cases it is a faulty strap.
    here is an interesting solution from dcrainmaker:
    A solution to heart rate dropouts/spikes with Garmin HR Soft Straps | DC Rainmaker
    Reputation: bbbr's Avatar
    I had similar issues with the Garmin hrm soft strap that came with my Edge 810 and ran down the list Natehawk mentioned. Nothing worked for more than a few days, in the end I replaced the strap with the Polar one from DC Rainmakers blog and the problems vanished instantly.
    Alea Jacta Est
  1. Question about defective inner tubes:
    By Furball the Mystery Cat in forum General Discussion
    Last Post: 04-30-2013, 03:53 PM
  2. Defective Big Fat Larry?
    By ferrstein in forum Fat bikes
    Last Post: 12-16-2011, 10:42 PM
  3. Defective Nobby Nic?
    By besnard in forum Wheels and Tires
    Last Post: 11-14-2011, 01:29 AM
  4. HELP! Is my fork defective
    By Ejuww2002 in forum Shocks and Suspension
    Last Post: 05-20-2011, 12:49 PM
  5. Defective X9 derailler?
    By mammothpunks in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2011, 07:58 PM
