Results 1 to 22 of 22
    Professional Sinecure
    Reputation: Schlubbe's Avatar
    My 705 - two hour old BRICK
    Software Missing
    Following the instructions I downloaded Garmin's updater software, hooked up my brand new 705, and now it gives me a software missing message when I turn it on. The downloader now says the update file is corrupt.
    Garmin is of course closed. For the holiday weekend. So now I either have a $500 brick for the weekend, or I see just how amenable Cabella's is to taking back this item. As I was the one who hooked a working unit up to garmin's downloader and now it doesn't work, I don't know how willing I would be to take it back. ( I am a retail manager at a different big box store and I'm pretty sure what I would tell me.)
    Anyone have suggestions?
    Schlubb
    Sinecureal Services Ltd. - Nobody Doesn't Better
    (it's Shluh-buh)
    Lucky...
    Ummm- "Mr Cabella's employee- this brand new, $500 toy does not work. I would like a replacement, please."
    Cabella's will RTV the 705 (as they should), you'll get a new device, and everyone is happy. The employee in the returns line won't give you a second look. No need to go into the nitty-gritty details, IMHO. Garmin's software bricked your 705, and they should have to replace it (whether the exchange occurs with you or Cabella's is immaterial).
    Exactly what happened
    Cabela's didn't even think twice about exchanging it.
    Tell ya this much, I don't plan on using the updater any time soon...
    McSchlubb
    (it's Shluh-buh)
    trail rat
    Reputation: slocaus's Avatar
    Quote Originally Posted by Schlubbe
    McSchlubb
    When this happened on two different occasions on my 305, I did a hard reset and then ran the updater again, after rebooting my computer, and having no other programs open or USB cables connected, and it reloaded the software fine.
    Given all the issues with the 705, and the thread that the update fixed many bugs, I'd opt for the update myself. But then I am waiting for you guys to solve all these things before I upgrade from my 305.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Lucky...
    McSchlubb
    I have used the updater twice on my 705 with no issues; downloads the update, installs it, and I reboot the 705. Worked flawlessly. The one caveat is I am using the Mac updater; the fact it worked so well on a Mac is somewhat of a miracle, IMHO.
    I would, however, not run the updater until next week when you can get Garmin support on the phone in the event of an issue.
    I'll think about it
    I'm going to see if the issues are something that bugs me- I expect I'll want to do the update at some point, but...
    Right now I'm trying to figure out how to put the speed/cadence sensor on (the store only had the model up from the one I returned.) The location they want has the hose from my BRAIN shock in the way, and it isn't something I can move. Might have to forgo the cadence function and just use the speed by mounting it on the seat-stay. Anyone seen this issue? (will post in the specialized forum too)
    schlubb
    (it's Shluh-buh)
    Lucky...
    Got a similar issue on my Yeti- the way the rear brake hose mount sits, I can't strap the cadence/speed sensor on.
    I have found the GPS speed/distance to be fine. It is what the system uses by default anyway, so the only time the unit uses the sensor is when it can't see the sky for a long period of time.
    I do miss the cadence somewhat, but not that much, since it's kinda tough to maintain a steady cadence on the trail.
    So you're saying if you worked there you'd have refused the exchange?
    i just finished the update on the 705...it worked (again, i'm on a mac.) One of the things that i do whenever i mess with firmware on devices is to make sure that I plug it directly into the machine and not via a hub. i did have a similar problem once on a 305 and the hard reset got me back to the original software setup.
    I might indeed have refused it...
    Let me explain my thinking-
    It worked fine when it left the store, I hooked it up to the computer and then it didn't work anymore. I may be a prematurely old f@rt, but I'm a person who always tries to take responsibility for my own actions and almost never try returning something I broke. I was feeling like it was something I did that caused it.
    In hindsight, there seem to be several people who have had the same problem, so I know it wasn't just me. And, given the cutthroat fight for business in modern American retail, I probably would have taken it back with a smile, just like this store did.
    (it's Shluh-buh)
    Reputation: jdr01930's Avatar
    For the benefit of anyone else who might find their shiny new Garmin Edge 605/705 "bricked" after running the updater, and come across this thread in a google rampage looking for solutions:
    If the unit says "software missing" and you can't do squat with it, call Garmin support and ask then to send you the file Edge705_2.20region.zip.
    It will fix the device and load up the current firmware, even if you can't see your Edge as a mass storage device.
    As of right now, you can't get that file from their website - maybe that will change,
    Ask for the file by name. First time I called, they told me I had to send it back. Some googling revealed this file name as a solution (thanks to gocycling over at the motionbased forums for posting the info!).
    When I called back and specfically mentioned this file name, they found the right info and sent it along.
    '15 Cannondale Trigger 27.5 Carbon 2
    '05 Prophet 1000
    '09 F3
    '93 Delta V 700
    '08 F6 Lefty (son's)
    Hi!
    I've got the same problem with my Edge 705. I will need it working tomorrow. Can someone send me the file?
    (luisfrf24@sapo.pt)
    Thanx,
    luisfrf24
    Does Garmin do any product testing at all before selling a $600 unit to the public? Seems to be a nice pattern with these guys.
    ... And I Am You,
    And What I See Is Me!
    Garmin 705 Missing software
    I've also got the same problem with my Edge 705. Can someone please send me the file? greg@sierra-corp.com
    Garmin Edge 705 Missing Software
    Sending it now.... Good luck!
    '05 Prophet 1000
    '09 F3
    '93 Delta V 700
    Software is no longer missing
    Thanks to everyone that helped. Unit works again and I'll have to be very careful the next update doesn't get interrupted.
    Jan 2011
    Missing S0ftware
    Hi, I may be a few years too late but found this forum after my 705 became a brick. Any chance someone could sent me the Edge705_2.20region.zip file? ceefers@gmail.com thanks in advance.
    trail rat
    Quote Originally Posted by Ceefers
    It is on the Garmin forums. You will likely have to register and sign in if you have not already.
    Ceefers - just sent you the file.
    Sometimes being an email pack rat comes in handy.
    Good luck!
    '05 Prophet 1000
    '09 F3
    '93 Delta V 700
    Also you can call Garmin support at 913-397-8200. Some of the best product support I've ever dealt with.
    trail rat
    Quote Originally Posted by gjmsd
    Might be tough to call that from Australia where Ceefers resides.......
