    Oct 2007
    Multiple cadence sesors with single 305
    Hi,
    Does anyone know if multiple cadence sensors (on multiple bikes) can be paired with a single 305?
    trail rat
    Reputation: slocaus's Avatar
    It will work. Each time you move it, go into the Menu and select Accessories and have the GPS head unit restart scan every time you mount it on a new bike so it can sync with that bike's GSC 10. Make sure you are at least 30 feet away from the other cadence unit or it will tell you multiple modules are found.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Oct 2007
    Thanks. I was just hoping I could sync it once with each and have it identify which one was sending data. I heard a rumor the 705 could do this.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by nbwallace
    IIRC it re-syncs with the cadence (and heart rate) transmitter every time the main unit is turned on.
    mtbtires.com
