Results 1 to 7 of 7
    Reputation: jgutz71's Avatar
    May 2012
    losing connection
    my garmin edge 510 keeps losing connection to my heart rate monitor...gonna try the update, hope that'll work
    Stumpy FSR Comp 29er
    SC Bronson C
    Fat-tired Roadie
    Nov 2007
    Where do you put the computer? I've noticed that if I put my ForeRunner in my jersey pocket, it doesn't work as well as if I wear it on my wrist.
    Also, are you sure it's the Edge-HRM connection that's dropping, and not a problem with the heart rate sensor? In some software, I notice lots of spikes to a 0 HR. I'm not dead, so I suspect a sensor problem.
    May 2012
    AndrwSwitch, I put the Garmin on my handle bars and it happened to two different heart rate monitors so I'd bet it isn't the Garmin but I could be wrong. It happened on the trail and when I went on a road ride. I just did the update for the Garmin so I hope that helps...
    SC Bronson C
    Fat-tired Roadie
    Nov 2007
    Interesting.
    I don't have any of the handlebar mount units. So I'm all out of ideas.
    Mar 2013
    my 510 hasnt had an issue with dropping any sensors with the old and new software.. what kind of jersey are you wearing? what sensor are you using?
    trail rat
    Reputation: slocaus's Avatar
    This issue has been noted with 305 and 705 in the past due to flapping jersey causing interference - solution was a baselayer over HRM strap. Also, using a conductivity gel will insure against loss of signal.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    May 2012
    I'm wearing one of those loose fitting moisture wick a way shirts or whatever they are called and I used both the bontrager and garmin heart rate sensors. They both dropped the signal when used with the 510 on the road and the trail...I have not used it since I downloaded the software upgrade...
    SC Bronson C
  1. Repairing a bad connection.
    By coghi in forum Lights DIY - Do It Yourself
    Last Post: 12-18-2012, 02:15 PM
  2. OT to Oden connection
    By kbabin in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 10-24-2012, 05:26 AM
  3. Garmin 500 connection to PC issue
    By jkirkpatri in forum GPS, HRM and Bike Computer
    Last Post: 09-26-2012, 10:39 AM
  4. The Ride Connection
    By BikeRayUSA-Michael in forum General Discussion
    Last Post: 04-23-2012, 12:17 AM
  5. Why the Stalkbook connection?
    By Haggis in forum Site Feedback/Issues
    Last Post: 03-02-2011, 03:45 AM
