Results 1 to 9 of 9
    Off the saddle
    Reputation: jizzim's Avatar
    Leashing Garmin Edge 810
    I currently have mine on a K-Edge mount and also have it covered in a white colored silicone case. I figured in the event of a departure from the mount I can easily spot the white color against the earthy trail.
    With that said, any of you leashing the GPS to the bike somehow? Obviously the 810 doesn't have a leash attachment or anything.
    since 4/10/2009
    Reputation: Harold's Avatar
    The 510 comes with this part, but the 810 has holes for it. Get something like this. You can probably find one cheaper if you scour ebay or Amazon, though.
    https://buy.garmin.com/en-US/US/shop...-11251-16.html
    Reputation: mikewadley's Avatar
    After almost losing my 510, I leash it to the bars now.
    Ride like you stole it!
    2015 Camber Carbon Expert EVO
    2015 Roubaix Sport
    2014 Camber Comp
    Off the saddle
    Quote Originally Posted by NateHawk View Post
    Unless you're seeing something I'm not, there are no holes on the body of the 810.
    since 4/10/2009
    Quote Originally Posted by jizzim View Post
    I don't have one in my hand right now, but I sell them at work. IIRC, the one we have on the shelf has a tiny little pair of holes for one of these. I won't be in again until Sunday to verify, though. I do see your point, though. Garmin doesn't list that lanyard as being compatible with the 810 on their site.
    You'd probably be able to put a lump of epoxy on and shape it with a dremel to make a tab for one of these on the back of the device if it really doesn't have one, though.
    Off the saddle
    Interesting. Please let me know. Mine was purchased just recently from REI so I don't know what's going on. But I definitely need to come up with a solution.
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    When I get some time ill try and snap some pictures.
    But hers what I did. I got a extra leash fro Contour ( I have two if there HD cameras) you can order them directly from Contour on their site. It's a two piece leash with a snap link in the middle.
    I put one end on my lager in mount using a "crows foot" then put the mount on my stem.
    The other end of the leash I attached to my 810. I attached it by removing the tiny screw that holds the rubber cover which covers the USB and memory card slot.
    I simply passed the loop over the USB side and the put the cover back in place and put the screw back in. The leash is now securely attached to the 810.
    When I ride I snap the two halves of the leash together and then put the 810 in the mount. The leash is maybe 1/2 inch total length so it stays in place and doesn't flap around. If the 810 comes out of mount it stays attached to the bike and the lease is short enough it won't bounce around too much.
    Off the saddle
    Outstanding DWill. Post a pic when you can.
    Off the saddle
    Is this how it's supposed to look? I found an extra camera lanyard and tried it out. The lanyard is long enough to be looped through the mount. It's aluminum so I don't see it going anywhere. I just hope the rubber cover holds.
  1. Garmin edge 800
    By socal59 in forum GPS, HRM and Bike Computer
    Last Post: 07-27-2012, 01:50 PM
  2. Garmin 800 vs. 500 Edge
    By Schril in forum GPS, HRM and Bike Computer
    Last Post: 06-26-2012, 01:43 PM
  3. What do you get with the Garmin Edge 800?
    By ljsmith in forum GPS, HRM and Bike Computer
    Last Post: 06-10-2012, 08:05 AM
  4. Garmin Edge 200 or Edge 500?
    By michael1 in forum GPS, HRM and Bike Computer
    Last Post: 03-14-2012, 01:40 PM
  5. Garmin EDGE 500 vs. EDGE 705
    By dadtorbn in forum GPS, HRM and Bike Computer
    Last Post: 11-05-2011, 10:03 AM
Members who have read this thread: 4
