Help please, How do I upload .GPX files on my Garmin 60CSx?
I have checked in the archives and found nothing. Even a google search did not yield the results I was looking for.
I'm looking to upload the .GPX files found on MTB Project | Mountain Bike Trail Maps onto my GPS. When I download a track, Mapsource doesn't recognize the extension. Do I need to download a specific program? If so, how do I go about transferring the track to the unit?
Rather be biking!
Thanks,
Stump
Google was no help?
 Originally Posted by Stump Grind
I...Even a google search did not yield the results I was looking for....
Google was no help "Downloading hikes in GPX format--Garmin GPSmap 60CSx"
<iframe width="560" height="315" src="//www.youtube.com/embed/-Nl7S-1ENCc" frameborder="0" allowfullscreen></iframe>
Go to the track and check to see I there is a "archive" option, once archived plug it into your computer and go to the archive folder and you should see your track as a .GPX, from there you should be able to upload straight to the site, that's what I do for strava.
This works on my etrex 20 so hopefully it the same. ( I choose to archive the track so I can figure out which track it is)
Good luck
Thanks guys.
Wolf, When I get to the point to open the saved file with Map source, MS can't see the download. Seems that it doesn't recognize the extension. Any idea?
File types?
Did you click on the arrow under file types to show gpx?
yes I did, now i Can find the file. When I then click on "open" I get an error message. "can not import goose-berry-messa.gpx"
Try another gpx file, could be something wrong with that one. I know it works because you can see it on the screen capture I just made and posted.
Yeah, maybe that site has bad files... Thanks for your help!
Have you tried putting the 60Cx in to USB Mass Storage mode as opposed to the Garmin Format? That's how I have to work my 76Cxi if I'm working through Strava. Strava only works direct with Garmin Edge type systems.
First, I suggest using a better program than Mapsource. Try Topofusion Pro. There is a free version.
You don't have to load it using a program. You can just use your file manager. Plug the GPS in to your computer's USB port. Turn it on. When the computer recognizes it, it will work like a thumb drive and you can see the files on the device. Look for the folder "GPX" and just drop the file in there. USB Mass Storage Mode is a good idea, too.
At least MTBProject puts out what should be Garmin-friendly .gpx files.
Wow, I finally did it! What a challenge for something that should have been so simple!
The Garmin support guy (very helpful BTW) got me 95% there but Basecamp couldn't upload the file to the unit for some reason. I used Topofusion as Nate suggested and now everything's groovy!
By 2gears=1speed in forum GPS, HRM and Bike Computer
Last Post: 07-08-2015, 06:31 PM
By cliffover3 in forum GPS, HRM and Bike Computer
Last Post: 07-09-2012, 05:39 AM
By Burning Matches in forum GPS, HRM and Bike Computer
Last Post: 06-15-2012, 01:42 PM
By steve@goaqualogic.com in forum Arizona
Last Post: 04-21-2011, 08:52 PM
By CarlS in forum GPS, HRM and Bike Computer
Last Post: 04-06-2011, 12:12 PM
- You may not post replies
- You may not edit your posts
Forum Rules
