Results 1 to 3 of 3
Thread: Help with GPS
    Help with GPS
    Any suggestions on getting a GPS unit that will work both on the bike and could also be used for driving directions (car)? Looks like the Garmin 605 and 705 would work but I am unsure. I would be using it equally as much for both (theoretically).
    bike fanatic
    Reputation: bike-always's Avatar
    I use the Garmin Map 60CSx for riding and in the car. I used it on a car and bike tour of the length of California a few month ago and it worked perfectly. Go to this link for a review of the GPS units used for bicycling. The 605 and 705 are pretty expensive for use in the car though.
    http://www.bicycle-touring-guide.com...smap60csx.html
    or the 76Csx
    http://www.bicycle-touring-guide.com...smap76csx.html
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    You should make sure whatever you get supports turn-by-turn directions for in car use. Other than that it's a comprimise between needs. I.E. smaller screen and overal smaller unit works better mounted on a bike but a larger screen works much better when navigating in a car or hiking.
    I have the 60csx and use it for both. Very nice unit and has removable micro sd storage. Very nice for quick switching between mapsets I have stored as opposed to having to download over and over. Not sure the Edge series supports removable memory or not.
