    Feb 2007
    Garmin Edge Mount - Big Rubber piece?
    What is the rubber piece used for the Garmin edge stem/handlebar mount? Go between the zipties and bottom of your bike stem to prevent rubbing and more secure hold?
    trail rat
    Reputation: slocaus's Avatar
    It is slightly angled, that one? It can be placed either way to change the level the GPS for easier viewing, but not needed. The mount itself has a rubber surface that makes it secure enough. Sometimes I use the wedge, sometimes not, it depends on the stem angle.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Feb 2007
    Quote Originally Posted by slocaus
    I figured that piece out and i used it to angle the garmin up so it clears my stem and offers better viewing angle.
    This bigger peice is just a flat rectangular piece of rubber about 1.5"x2" long and 1/8" thick.
    GeoMan
    Reputation: GEOMAN's Avatar
    Quote Originally Posted by iRoNeTiK
    Zactly!
    The bigger piece is for added dampening or for a shim as you wrap it around your stem or bar...
    GeoMan
    We Ride!
    www.geomangear.com
