    Reputation: GlennW's Avatar
    Jun 2012
    New question here. Garmin Edge 800 woes - alternatives?
    Been having a few issues with my Garmin Edge 800 which seem to be getting more common recently, namely the unit freezing, turning itself off, the touch screen not working accurately (no matter where you touch the screen on the map view it only activates the on screen buttons at the bottom of the screen, not those at the top). I've tried resetting the unit which might improve things for a short while, but then the problems reoccur...
    This is starting to grind rather and I'm wondering if there are any credible alternatives to this unit?
    I need the map & guidance feature on my gps.
    Thanks in advance for your input.
    Not really doing much Ridin' or Diggin'
    mtbr dismember
    Reputation: Wherewolf's Avatar
    Replace it
    Even if it is no longer on warranty Garmin will replace it for $99.
    Jun 2013
    Quote Originally Posted by GlennW View Post
    Glenn, have you any resolution to the problem? I'm a fellow 800 owner and the screen has frozen one time recently, so it gives me cause to worry.
    Quote Originally Posted by Wherewolf View Post
    May not be acceptable to the OP (or me), because they might simply give another 800 that will have the same problem a year from now. $100/yr is not my idea of reliable.
    Jun 2012
    Things seem to have improved a bit - I'm now being very carefully about correctly ejecting the GPS from my laptop each & every time and I'm also doing the screen calibration before pretty much every ride.
    Not ideal, but improved.
    I look forward to the day when we have a GPS unit which has a touch screen that works as well as an iPhone.
  1. Garmin edge 500 or 200?
    By cormy in forum GPS, HRM and Bike Computer
    Last Post: 05-27-2012, 03:29 PM
  2. Garmin Alternatives
    By Evan55 in forum GPS, HRM and Bike Computer
    Last Post: 04-23-2012, 09:33 AM
  3. Garmin Edge 200 or Edge 500?
    By michael1 in forum GPS, HRM and Bike Computer
    Last Post: 03-14-2012, 01:40 PM
  4. Garmin EDGE 500 vs. EDGE 705
    By dadtorbn in forum GPS, HRM and Bike Computer
    Last Post: 11-05-2011, 10:03 AM
  5. Garmin Edge 605 $199
    By Trabso in forum Where are the Best Deals?
    Last Post: 03-16-2011, 08:32 AM
