Results 1 to 7 of 7
    garmin edge 800 temp readings
    i have a edge 800 which has the temperature reading on it. i was curious how accurate everyone thinks this is. it seems to be consistently higher then what i see on the online weather sites for that same day and time.
    Reputation: ghettocruiser's Avatar
    It's black and the sun is shining on it?
    It's more accurate on cloudy days and at night, although the display and other electronics generate a little bit of heat as well, I suspect.
    Otherwise, it makes you feel more badass on hot summer days and less badass on cold winter days.
    The above statements have not been evaluated by the Food and Drug Administration
    mtbr dismember
    Reputation: Wherewolf's Avatar
    It runs a little hot when in direct sun. But official temperatures are usually from airports and not on the trails. When on an open rocky trail the temperature is often much higher than reported.
    Happy Trails
    Reputation: Scott In MD's Avatar
    Real temp is measured in the shade without the radiant energy from the sun. Mine does the same thing. Keep in mind that that radiant energy is beaming down on you too, so your Garmin is trying to tell you to stay hydrated.
    Reputation: dirtyjack's Avatar
    I noticed in winter that mine reads 2-3 degrees lower than what my truck says when driving to the ride . And my buddy's is always a couple of degrees higher than me.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by dirtyjack View Post
    Any bike computer is reporting the temp inside the case. And a few degrees of variation is normal, device to device and even minor location changes.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    yep. I just assume that at night, mine reads about 3 degrees low. Can't say how accurate the daytime temps are.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
  1. Garmin external temp sensor
    By Harold in forum GPS, HRM and Bike Computer
    Last Post: 07-11-2012, 04:24 PM
  2. Garmin Edge 200 or Edge 500?
    By michael1 in forum GPS, HRM and Bike Computer
    Last Post: 03-14-2012, 01:40 PM
  3. Edge 500 low HR readings
    By MTBkid SA in forum GPS, HRM and Bike Computer
    Last Post: 03-08-2012, 12:35 AM
  4. Garmin EDGE 500 vs. EDGE 705
    By dadtorbn in forum GPS, HRM and Bike Computer
    Last Post: 11-05-2011, 10:03 AM
  5. Edge 800 temp readings
    By Jesterrider in forum GPS, HRM and Bike Computer
    Last Post: 02-06-2011, 07:01 PM
