Results 1 to 9 of 9
    Garmin Edge 705 Cadence Issue?
    Im just getting back to riding my new bike, and i have the cadence unit mounted on the chain stay, with magnet on wheel and one on the crank. When i power on the unit, both Cadence and HR are detected by the unit. On my main display i have 8 windows, 2 of which are HR and Cadence. After about 5 or so mins and some adjusting the HR starts to pick up, my understanding is that with perspiration the HR strap starts to work better. So heart rate is working, but as im spinning the crank, the Cadence section on the display is showing ---- RPM. i spun the crank for a good bit and nothing ever showed up the screen.
    Anyone seen this issue or know if there is some setting im not doing properly?
    When i press the test button the cadence sensors the light flashes showing that it is picking up the magnets passing (signal)...
    So what could the issue be?
    Thanks,
    Alex
    www.garabaghi.com
    more photos
    www.tripxamerica.com
    Reviews by riders.
    Hifi => Ex 9. Thank you warranty.
    The MTB Lab
    Reputation: pastajet's Avatar
    Try a fresh set of batteries?
    Why would i need fresh batteries is the light flashes in test mode when both the cadence magnet and the wheel magnet pass it.
    I guess its just a watch battery type thing so ill give that a try...
    Ideally it should have been reading cadence even if i was just cranking the crank on the stand right?
    www.garabaghi.com
    more photos
    Reviews by riders.
    Super Ginger
    it is flashing red for your cadence correct? I had the hardest time getting mine lined up also. I am now having issues getting my USB drivers loaded properly.
    2013 Jamis XCT 650b Pro
    2015 Merckx Mourenx 69
    2017 Orbea OIZ M20
    what do you mean correct? i press and hold it, it goes solid for a second. then turns off... when the crank passes it it flashes, and when the wheel passes it it flashes...
    www.garabaghi.com
    more photos
    Reviews by riders.
    Super Ginger
    Flash red for cadence and green for the wheel. Mine was flashing green only for a while.
    2017 Orbea OIZ M20
    Im dumb. Turns out the magnet was flashing red (but i guess not fully), i repositioned the magnet and now it flashes much brighter and the unit reads.
    www.garabaghi.com
    more photos
    Reviews by riders.
    Super Ginger
    good job!!
    My next suggestion was yelling obscenities at it, that seems to be what worked for me.
    2017 Orbea OIZ M20
    so who is good with hydraulic brakes?
    aim: bga49
    haha
    www.garabaghi.com
    more photos
    Reviews by riders.
