Results 1 to 19 of 19
    Garmin Edge 510 directly to Strava
    Can I upload my Garmin Edge 510 directly to Strava? Right now I am loading the Edge data to GarminConnect and using CopyMySports to send it to Strava. For some strange reason some of the data is different in the 2 programs. I would like to just send it straight to Strava, is this possible?
    Reputation: mikewadley's Avatar
    I haven't tried but would be interested also so I could share with non-Garmin users.
    Ride like you stole it!
    2015 Camber Carbon Expert EVO
    2015 Roubaix Sport
    2014 Camber Comp
    May 2012
    I'm pretty sure you can Bluetooth the 510 directly to strava, log in to strava then click upload and see if it doesn't give the 510 option to select
    I'm not sure that's the case. I can pull it directly from the unit to Strava when it is USB wired to the computer, but I want to send the data wirelessly to Strava. If it does this I haven't figured it out yet.
    Quote Originally Posted by shreddr View Post
    I couldn't get the wireless to work but the USB worked perfectly.
    2015 Roubaix Sport
    2014 Camber Comp
    since 4/10/2009
    Reputation: Harold's Avatar
    Strava will do wireless over ANT+ if your receiver will upload via that protocol. I am not sure about bluetooth and I am not sure about the edge 510 but my Forerunner 310xt uploads wirelessly to strava over ANT+.
    Jan 2013
    I use Tapiriik to sync my Garmin Connect with Strava. When I first started using it there was a difference in elevation data between the two. This has since been fixed. I'm totally happy with it now.
    I use CopyMySports. Works well most of the time. I upload rides to my smartphone via bluetooth and the Garmin Connect app. Then CopyMySports wirelessly uploads it to Strava automatically.
    More complete info on how to do this and the other options (including Tapirrik) here: 3 Ways to Automatically Copy Your Garmin Training Data to Other Fitness Sites | DC Rainmaker
    i posted the question on the Strava website and this is the response i got:
    Hello-
    Unfortunately not; it's not possible to upload from your Garmin to Strava over Bluetooth as Garmin has not made this functionality available.
    Sorry for the trouble.
    Mat
    strava.com/athletes/mat_gordon
    Strava Support Team
    ________________________________________
    Well, its not in Strava's direct interest to facilitate this, so they don't go out of their way to make it possible. But third party tech folks like the ones at CopyMySports and Tapirrik have found a way to do it. I know, I've personally used them.
    They're not perfect, and can sometimes fail to sync a particular ride or take many hours to do so. But they do work achieve what I think the OP was going for.
    Hello-
    Mat
    Strava Support Team
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    I use an app on my iPad called ConnectStats. It can view your Garmin Connect data, and also has a one-click upload for Strava. I got frustrated with CopyMySports due to the lag times for upload and the fact that it only seemed to work seamlessly about 70% of the time. I think the ConnectStats app is available on other platforms, not just iOS.
    1. Ride
    2. Upload from edge 510 to Garmin connect via phone bluetooth connection
    3. Upload to Strava from ConnectStats on iPad.
    Ride More, Work Less
    Reputation: heyyall's Avatar
    ^ Interesting idea. I also have connectstats but didn't know it did uploads. I may give this a try too as CopyMySports isn't working these days.
    I experimented with the connectstats upload. At first, I couldn't figure out how to make it work. It also doesn't seem to work with all activity types. For example, it wouldn't upload a walk. It wouldn't upload a hike. But if I edited the activity to be a bike ride, it uploaded without an issue. I can see lots of use for this. Thanks for sharing.
    AOK
    AOK is offline
    Glad it worked out for you. I have been happiest with this method.
    The only drawback is that as a "little guy" the ConnectedStats developer gets hit with changes to Strava and Garmin occasionally. Last summer/fall Strava changed their API and the upload feature didn't work for a few months. Recently Garmin changed their API and he was down again, this time for only a week or two. He is really good about quick app updates once Strava/Garmin release their new APIs.
    Hopefully these were isolated incidents. Other than these two outages the app has been flawless.
    Mar 2013
    I don't mind downloading from the Garmin device (510)
    via USB to Strava but it takes forever, is there something I'm missing here? My old edge 500 I would connect to my computer via USB and my ride would be uploaded to Strava in a minute or so.
    Are you downloading or syncing all activities each time? I upload every time I ride and it's pretty quick on my 510.
    Quote Originally Posted by Dave M View Post
    2015 Roubaix Sport
    2014 Camber Comp
    And once you get the items uploaded, delete all rides from the garmin. Then, delete all ride every five or so rides.
    Craigslist & MTBR --free ads for all
    Mar 2013
    I have the same problem with my 510, I will ride then connect via USB support to computer and sometimes it syncs within seconds but most of the time I have to keep hitting the button "no device found" after countless numbers of attempts it will finally work, never had this problem with the 500, is there something else I should try??
    Reputation: WR304's Avatar
    If you're connecting the Garmin to a PC with a USB cable you should be able to see it listed as a mass storage device in My Computer.
    If you can see the Garmin browse to the Activities folder, copy - paste the .fit file onto your computer's hard drive and then use the Upload From File option in Strava to upload the file from there.
    If the Garmin isn't showing up as a device in My Computer it could be a bad USB connection. It might be worth trying a different USB cable and using contact cleaner on the USB port.
    http://store.caig.com/s.nl/sc.2/category.188/.f
  1. Strava - Garmin Edge 705 or iPhone 5 app ????
    By lasvegascfp in forum GPS, HRM and Bike Computer
    Last Post: 10-23-2013, 03:31 PM
  2. Creating Garmin TCX Courses from Strava GPX in Garmin Connect
    By canuck_tacoma in forum GPS, HRM and Bike Computer
    Last Post: 08-14-2013, 08:50 PM
  3. Strava segments onto a garmin
    By wobbem in forum GPS, HRM and Bike Computer
    Last Post: 07-24-2013, 08:38 PM
  4. Edge 510 and Strava...
    By jgutz71 in forum GPS, HRM and Bike Computer
    Last Post: 07-01-2013, 06:33 PM
  5. Looking for a little help: Strava activity to Garmin Edge 305
    By vuduvgn in forum GPS, HRM and Bike Computer
    Last Post: 04-21-2012, 06:56 PM
