Results 1 to 35 of 35
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    Garmin Edge 500 data loss
    My apologies if this is a duplicate thread, but I couldn't easily find reference to this issue with a search of the forum.
    On Saturday, I did a 67-mile ride with 5700 feet of elevation change on gravel in southwestern Wisconsin. The Edge 500 looked like it was working just fine the whole time. At the end of the ride, I stopped the timer, held down the reset button for the duration of the countdown, waited for the distance to zero out and then powered down the unit.
    Upon connecting the device to my home computer in the usual fashion, neither Garmin Connect nor Training Center were able to find the activity. Navigating to the data revealed that there was no fit file for the date and time at which it was supposed to have been saved.
    Further digging through the file system revealed BEE.BIN and ARC.BIN files with modification dates that correspond with the end of the ride and file sizes that suggest the data may be contained there.
    I'd like to find out whether this ride data can be salvaged. Scoring for the event in question consists of posting GPS data online.
    There are numerous posts about this on the Garmin forums, but I wonder whether anyone here has dealt with this? I've recorded dozens of rides with this unit, so it's disappointing to say the least that it would fail at random.
    Thanks in advance for any insight...
    trail rat
    Reputation: slocaus's Avatar
    $#!+ happens.
    Cars break down, bikes break down, power goes out at home, cell phones drop calls, babies puke on you, dogs crap on the lawn, humans make mistakes.
    $#!+ happens.
    Nothing is 100% perfect and reliable all the time. Period.
    One of these utilities might, MIGHT, work.
    (standard disclaimer, use at your own risk, if it goes wrong, you did it, not me, no pixels were harmed in this reply, I am not a gps expert nor do I make a living in the gps world, I am just a rank amateur. ad nauseum....)
    Garmin TCX Builder
    TCX Converter - The multiconverter tool
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    since 4/10/2009
    Reputation: Harold's Avatar
    I have no experience with that model, so I can't help you much. I do know that with my GPS (Oregon 450), it will auto archive track segments and so on a long ride like what you did, I will have to go back and piece the segments together on my computer before uploading. It works well.
    Sounds like you did some kind of Strava ride or something? At any rate, is it possible to do the ride again? You may not be able to salvage the data from your GPS.
    Fact is, electronics fail sometimes. It doesn't matter who made it or how much it cost. If it is THAT important that you get the data, you need redundancies.
    Oct 2007
    Quote Originally Posted by slocaus View Post
    $#!+ happens.
    I work in IT, so I'm well aware, thanks. But looking at the forums over on garmin.com, it looks like they've been aware of this issue since early- to mid-2010. I'm a lot less willing to cut them slack than I might be were I say, testing something in beta. If it's a mature product, it should reliably do its job. If it can't reliably do its job, folks might benefit from knowing so before they plunk down $250-$350. That's part of why I'm posting here.
    That said, thanks much for the links. I'll give those a shot.
    Oct 2011
    Might try contacting Garmin Tech Support and see if they have any ideas. When I first got my 800 I had a few issues somewhat like that and I did a couple of different resets and I think I was able to get all the saved information back. Not familiar with the 500 model, though.
    trail rat
    Quote Originally Posted by MauricioB View Post
    Thanks for appreciating my approach and warped humor. Let us know if it works out with the utilities. I've used them on my 705 once or twice in the last three years.
    Oct 2007
    Right, thanks for the links to the utilities.
    The TCX Converter doesn't recognize ARC.BIN or BEE.BIN files.
    I don't have a PC handy to try the TCX Builder. I could get my paws on something, but I wonder whether you know if it can actually read the .BIN file type?
    See, here's my theory: the Edge writes data to the ARC and BEE files in the ExtData folder during the ride, and then upon Reset, converts them to FIT files and drops them into the Activities folder. Somehow, this process must error out or crash, resulting in a FIT file not being created or populated.
    The question is whether the ride data is really in the BIN files and if so, whether it can be put back together by anyone besides Garmin.
    Reputation: ghettocruiser's Avatar
    When I turned my 500 off by mistake while logging, I still got a FIT file that ended abruptly.
    The above statements have not been evaluated by the Food and Drug Administration
    trail rat
    I do not know, and Garmin has been rather closed about the .FIT file documentation, much to the discontent of many third party software developers. The best I can find is this:
    https://forums.garmin.com/showthread.php?t=4219
    Format of activity .FIT files created by Garmin Edge 500 (incomplete)
    I know the 705 writes the raw data as .dat files in the /laps folder. When you reset and connect the USB or power cable, those many .dat files are built into a .tcx file in the /history folder. And that is what the TCX builder can do when Garmin fails.
    You likely have some research. I know that Garmin changed from the .tcx which is an enhanced .gpx xml file format with the 305/705 and the new .FIT file format came with the 500/800. Also, documentation stopped for some time, but that link seems to be the only info out there, and you need the FIT SDK to do more.
    I'm over my head at this point. Good luck.
    Oct 2007
    I seem to remember reading on their forum that FIT includes some code for supporting ANT that's proprietary. I could understand their not wanting to get into NDA trouble.
    I'll check there too. Fortunately I haven't done any rides since the data loss.
    Oct 2007
    Quote Originally Posted by 4Crawler View Post
    I have a case in to them, but have not heard back yet (24 hours hence.) Fortunately, I haven't recorded a ride since.
    Oct 2007
    Many thanks
    Several good insights in this thread. A big thank you to all who responded. I'll post again in a day or two and let you know what I find out...
    Reputation: shiggy's Avatar
    Dec 1998
    I never reset before I shutdown. Just stop the timer. After I download the data the unit is reset. I will reset before the next ride if I did not download.
    mtbtires.com
    Oct 2007
    Quote Originally Posted by shiggy View Post
    I could try that, though resetting follows the FM's instructions and has worked for dozens of rides. Also note that there are many posts on the Garmin forums from people who have done as you've described and thought it was the cause of the problem.
    The Edge 500 suffers from an intermittent data loss problem. Don't think I could recommend it to anyone.
    since 4/10/2009
    I found my Edge 705 to be fussy (never to the point of data loss, but other minor issues) if I didn't press reset at the end of the ride. Same with my Forerunner 205.
    Dec 1998
    Quote Originally Posted by NateHawk View Post
    Hmmm...that was never the case with my Edge 305 or 800. I would get weird tracks if I turned the unit on again before downloading.
    The 200 I just picked up does ask if you want to save or discard a ride when you turn off the timer.
    mtbtires.com
    Oct 2007
    I'll check there [in the raw data for .dat files in the /laps folder] too. Fortunately I haven't done any rides since the data loss.
    Alas, the 500 seems to have no /laps folder...
    since 4/10/2009
    I'd get that, too, but it wasn't the only issue. I don't even remember now. that was very soon post-cancer and I don't remember a lot from then.
    Reputation: jetboy23's Avatar
    Last time i tried to upload a ride without resetting it, i think i wasn't able to find it. I had to reset for the activity to be created. I haven't lost a ride like the OPer. If i did, i would be mad. Thats about the milage i get in a whole month. Hope Garmin can help you out. Let us know if you get it back.
    I do mine just like Shiggy said. When your done with your ride, stop the timer, then just turn it off. I have never used the reset function. Once you download the ride, next time your ready, just turn it on and start the timer.
    I too have never once reset. All I do is stop the timer, and turn it off. Then when I get home, upload. Never even knew about a need to reset.
    trail rat
    Quote Originally Posted by trmn8er View Post
    Reset is needed if you do not upload between rides, the Garmin performs its own reset when it detests the USB connection. The reset converts the temporary data accumulated in the ride (still having data added), to the final result that can be parsed by whatever software you upload the final ride data.
    If you do a second ride in the same day or consecutive days without reset or upload, they will show as one single ride with a long pause in the middle. That is why the manual reset is there.
    since 4/10/2009
    Yes, that's the other issue I had before I did the manual reset, and I think I had that happen on my Forerunner shortly after I bought it and started using it. The manual reset takes 3 seconds, so I found it easier to do that cutting two days' tracks apart.
    Oct 2007
    Final Tally
    So, the results are in.
    The post over at the Garmin forum on this issue has languished for a week. Not holding out any hope there, though I did archive the BIN files from that day.
    Garmin tech support got back to me also (this was the second message):
    I am sorry for not being very clear. I wanted to ensure that when you disconnected the Edge that the timer pages were "0:00" and not still showing any times. Often when a previous days activity is stopped but not saved that activity will then be corrupted if allowed to continue over a 24 hour time frame and all activities will have this date going forward unless this corrupt file is deleted.
    [Mind you, I had told them that I had reset immediately after the ride and that the timer, etc. showed zero.]
    Here are some precautions that would be advised to keep this from happening going forward,
    -Ensuring that the unit's system software is up to date
    -Ensuring that any and all previously uploaded activities have been removed from the unit after being transferred to the computer
    -Ensuring that the Edge has had enough time to acquire in the start of the activity
    -Being sure to reset your activity after stopping and finishing for that days events.
    -Ensuring that your Garmin Communicator Plug In is up to date.
    Except for "all previously uploaded activities [...] removed," all of this checked out. There was 45+MB of free space on the unit the day of the ride, so this shouldn't be a case of the storage space being full. Also note that there's nothing in the manual about removing previous activities.
    There are alot of users that operate the Edge 500 for recording thier data. The units operation can depend on many factors. Because we all use and care for our units a little differently, there will be varying results. If these steps are used or incorporated into your routine, this should help minimize the chance of the unit failing to operate as designed.
    Perhaps this paragraph is not intended to do so, but it sure sounds like "this is your fault, chump. $#!+ happens."
    Did another ride on Sunday and it worked fine. Same as usual, except that I no longer trust it.
    Could anybody recommend a non-Garmin unit for under $250? Bryton Rider 35?
    Oct 2007
    Just for the record, I lost another ride data file this morning. Two missing files in as many months qualifies this unit as unreliable as far as I'm concerned.
    So, anything new from the competition?
    Have you ran a scan of the device from windows using disk check?
    Last time I plugged mine in I got a message that memory errors had been found and fixed. Whether or not this really means anything I dunno, since I've had no loses.
    Oct 2007
    Quote Originally Posted by ghettocruiser View Post
    Thanks for the excellent suggestion. I'm using a Mac, so I've used both Disk Utility and the UNIX command-line disc checker, and neither found a problem. Might try a Windows utility next.
    Cheers!
    trail rat
    Do you clear all the track data from the device as soon as you download it? It is good to upload to whatever online, but keep a copy locally archived. Lots of ride tracks on the device will cause these issues.
    On the other hand, you will probably be better with a wired bike computer that can give altitude as well as the other stats.
    Oct 2007
    Yes and no. I do eventually archive the data, but not for lack of space. I have something like 15 rides on the device right now, totaling a couple of MBs, but it still has almost 50MB of free space. Is that what you're getting at?
    I've used Planet Bike wired computers for years, and going back to those would be a good solution if I weren't so interested in where I've been. Also, the Edge 500 has an altimeter.
    trail rat
    Not sure this applies on the 500 like my 705, but likely. The GPS loads most if not all data into memory when on, track, routes, courses. That is because they all need to be available since rereading from he device on menu selections would be slow. Data loss errors like yours happen more often when there are many tracks stored. I move mine off ASAP, usually have no more than three. Never lost a track since I started that. Only lost one early with 50 tracks.
    - via Kindle Fire w twa_priv ICS / CM9 linaro based on SG7 & Hashcode 3.0 kernel - Tapatalk 2
    3D guy
    Reputation: gstahl's Avatar
    Note: my wife's 500 is in a desk drawer. I have her using a 705. I tried the 500 (figure I must be able to keep it reliable)... I am now using an 800.
    For the life of me (this is about a year or so ago) I could not keep the 500 from losing data at times. 705 and 800 have been great from the data perspective (I have owned a ton of garmin devices and this is the only one I have seen with this issue)
    Geoff Stahl
    San Jose
    BLTc, Chameleon Single Speed, Speedvagen Road
    Apr 2013
    I have had exactly the same problem with the edge 500 on two occasions, my first data loss was a 67 mile ride, sent file to garmin tech support! You've guessed the data was corrupted-all data lost! Was told about resetting unit at end of ride! I again lost data this Sunday only on a short ride! However on both occasions it has been when I have been using the HR unit, I have used it on other rides when unit has worked ok! I am however a little disgruntled after reading the threads on here, as to its reliability now and in the future! Am I best to put it down to experience and purchase a unit with more reliability?
    May 2013
    Quick question...I have an Edge 305 and it lost one of my rides. How were you able to connect and see this device as a regular usb drive to read the file system? thanks.
    Apr 2015
    This is old but, I made a Mac version of the TCX Builder. Can you send me some bin files to see if this is something that can be fixed?
    https://github.com/adammendoza/Garmi...lder-Mac-Swift
    Natural body armor
    Reputation: Zen_Turtle's Avatar
    Quote Originally Posted by adammendoza View Post
    Thanks for porting this to the Mac world.
    But I think this does not apply to the newer devices like Edge 500/800 etc as the file system is different. There's no 'laps' folder on the 800.
    Try to help a friend who lost her 130 miles ride on Edge 500: Thanks a lot Garmin!
    "There is no A-line"
    Savvy Bike
