Results 1 to 8 of 8
    Apr 2013
    Garmin 810 Question
    I am thinking of getting the Garmin 810 for my mountain bike, my concern is the way it mounts onto the stem, the set up looks flimsy. Has anyone had any problems with the Garmin becoming loose or falling off during a ride?
    mtbr dismember
    Reputation: Wherewolf's Avatar
    No problem
    It has the same mount as the 800, which is by far the best mounting system I've seen.
    since 4/10/2009
    Reputation: Harold's Avatar
    Garmin 810 Question
    I have an adapter for my Forerunner 310xt that uses the same mount system. It's a great mount system. It works well
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    The mount well. I have had my 810 come off once in a crash, I hit it with my leg when my bike slide out but I have a leash on it that I borrowed from my Contour Camera so it stayed with the bike.
    I also have a the silicone case Garmin sells for it and a screen protector. I highly recommend both especially the screen protector if you use gloves on the screen.
    Re: Garmin 810 Question
    My mount popped off on the drive home. I realized when home and immediately went out to find it, which I did 10 minutes later. It was still attached to the mount, partially, but cracked. 2 months old.
    I wouldn't use the rubber band mount.
    Sent from my SCH-I535 using Tapatalk
    since 4/10/2009
    Quote Originally Posted by mhopton View Post
    My mount popped off on the drive home....
    Don't leave your GPS on your bike when your bike is on the car rack.
    Yeah, lesson learned. This was my first Garmin....
    since 4/10/2009
    If it's not bolted on, take it off when you put it on the car rack.
    It might be worth contacting Garmin. You can probably work out a deal with them where they'll send you a refurbished model for a modest cost so you can "repair" the screen. It's also possible you could find someone offering to repair broken screens somewhere. Businesses doing that for smartphones do a pretty bang-up business that they're all over the place.
  1. Garmin 500 question
    By Passenger13 in forum California - Norcal
    Last Post: 12-17-2012, 07:22 PM
  2. Garmin 500 question
    By cabbgage in forum GPS, HRM and Bike Computer
    Last Post: 08-16-2012, 10:36 AM
  3. Garmin 500 question
    By pmarshall in forum California - Norcal
    Last Post: 04-03-2012, 10:32 PM
  4. Garmin 305 question
    By MI-29er in forum GPS, HRM and Bike Computer
    Last Post: 01-14-2012, 06:07 PM
  5. Garmin Edge 500 question
    By Hvnfun in forum GPS, HRM and Bike Computer
    Last Post: 08-05-2011, 04:53 PM
