Results 1 to 11 of 11
    Reputation: KMan's Avatar
    Garmin 705 waterproof?
    is the 705 waterproof? If I'm caught in downpouring rain, the 705 should have no water issues? Just want to make sure.
    www.MLKimages.com
    Older & Faster...downhill
    yes. you can drop it in the creek for a few minutes without worry. don't go scuba diving with it though.
    The 305 manual says that it is waterproof for something like "30 ft underwater for 20 min" or so, and I imagine the 705 would be the same.
    trail rat
    Reputation: slocaus's Avatar
    GPS Magazine Hands On Review
    The entire Edge 705 casing is sealed to protect the unit from the elements (the Edge 705 is waterproof rated to IPX-7 standards, meaning it can be completely submerged in water for up to 30 minutes).
    This also has many excellent screen shots!
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    I put mine through the clothes washer. Found it before it hit the dryer. Was fine.
    since 4/10/2009
    Reputation: Harold's Avatar
    I would suggest if you push those waterproofness limits, you pull the batteries out and dry it off. My 76CSx (same waterproofness rating) got thrashed in a river for awhile before we got it (and the canoe it was lashed to) unpinned from the rock. It still worked, but water got inside. By the time I got home, it did not work. So I removed the batteries and trained a hairdryer on it...and then let it sit about 24hrs before reinstalling the batteries. It fired back up then, but it definitely had me worried.
    trail rat
    Quote Originally Posted by NateHawk
    You can flood it with rubbing alcohol to soak up the water too, will not hurt the electronics. Just dry it will before turning it on.
    The 705 is sealed battery, so you cannot remove it easily.
    since 4/10/2009
    The battery compartment on mine is supposedly sealed, too...but plenty of water still got in. This was no simple dunking, either, but a straight thrashing. Still, important to check IMO, anytime the GPS gets wet from more than a rain shower.
    If the rubber mini USB port cover is not on tightly then water can get inside the 705.
    Quote Originally Posted by Resist
    You definitely don't want your rubber to be loose.
    Reputation: HuffyPuffy's Avatar
    Since it is just a plug, it fell out of mine in the first week, poor design IMHO.
