    Garmin 705 Speed/Cadence Sensor
    I'm thinking about getting a 705 and with the middle model it adds the speed and cadence sensor. I'm not too interested in cadence but does it give more a more accurate speed reading with the sensor or is the GPS calculated speed better? Thanks!
    Lucky...
    By default, the unit uses the GPS speed- only uses sensor data when it can't see the sky. I have the sensor, but don't even have it mounted to the bike.
    I was kinda curious about this too.
    How often does the gps cut out(i am guessing it depends on terrain)?
    is the cadence really needed or is it more for roadies?
    Thanks for the info Mr Bacon Jr. From what I understand, the signal strength is usually good as long as your not in an urban, downtown setting. I think I'm going to go with the lowest model cause I dont care about cadence on my MTB and I already have a 2GB microSD.
