Results 1 to 3 of 3
    Garmin 305 HR Monitor with 500 Head
    Does this combo work? Can seem to get a signal, but I am not sure if it is the monitor or a compatibility issue and it will make a difference in which one I order as a replacement. Thanks in advance for the help.
    Reputation: ghettocruiser's Avatar
    yes.
    anything using ANT+ is fully compatible (hard as that may be to believe if you used HRMs 5+ years ago)
    I'm using a Timex HR with a 500 head right now.
    The above statements have not been evaluated by the Food and Drug Administration
    Reputation: yellowducman's Avatar
    Yep, my Garmin heart rate monitor works with my 500, 800, and forerunner.
