Results 1 to 2 of 2
    Reputation: ShaggyRS6's Avatar
    Garmin 305 to 705 Issues
    Hi,
    I have been using an Edge 305 for the past month, I have upgraded to a 705 but I have a slight issue.
    Neither Sports Tracks or Motion based nor Webupdate will find the 705, Training Centre Communicates with it and see's it as a 705, my PC only see's it as a storage device.
    I have installed everything, and then reinstalled. I have installed the communications plugin.
    One thing I have noticed that the 705 does not do and my 305 did (and this may be a red herring) is although there is power going to it when its plugged into my PC (it has the little Computer symbol showing) I cant turn it on whilst its plugged into the comp. I used to be able to do this with the 305.
    Any suggestions?
    09 Scott Spark 35
    25lbs of Pure Awesomeness
    trail rat
    Reputation: slocaus's Avatar
    You probably need the Garmin Communicator plug in from here.
    edit: You have to reconfigure SportTrack for the new device, and check for updates. Also a new WebUpdate was just released a few days ago., here. Do you have it?
    From what I know, you cannot turn on the 705 while connected, but do the "remove device" and it will charge. Why is this a major issue for you?
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
