Results 1 to 9 of 9
    Flashing Cadence Symbol on Edge 305
    hello, I've recently noticed that my cadence symbol has an "X" flashing through it. Cadence is registering and the numbers look right, so I feel that the Edge is linked to the cadence sensor, but I cannot get the flashing "x" to go away. I'm talking about the cadence symbol that shows up at the top of the Edge's screen, right beside the heart symbol.
    I'm running 3.2 and so I tried going backward on the firmware. Went all the way to 3.00 and still have the flashing cadence symbol. I also have performed a master reset.
    Anybody else experience this? What are my options to resolve it?
    Thanks,
    Steig
    Reputation: dnoyeb's Avatar
    You may experience that when the signal keeps disappearing. Are you watching average or actual cadence on the Edge? Maybe the battery is low.
    I just replaced the cadence sensor with a new battery and the results are the same, so the battery isn't the problem. I'm watching actual cadence on the edge and it has always reported it acurately, so that isn't the problem either. The problem is that the cadence symbol (at the top of the Edge's screen) is flashing an X all the time.
    Hack Racer
    Reputation: Cheers!'s Avatar
    Quote Originally Posted by steigw
    If the cadence symbol on the top of the screen in the status bar is flashing X it means the garmin edge 305 unit is not registering your cadence/speed sensor. But you say that your unit shows the cadence correctly, which is odd.
    Try rescanning for the cadence sensor under the settings menu. Or try resetting the cadence sensor by pressing the opaque rubber button down on the cadence sensor it self.
    It means its not getting a reading from one or the other i.e. crank or wheel
    Chances are your wheel sensor is not reading and you will never notice if you are riding as the GPS takes precedence. Try spinning the back wheel while standing still and see if you get a reading (sometimes you have to turn the GPS off).
    I get this all the time when the Spinergy wheels are on the bike as I have no spoke magnet for those wheels.
    KIN
    Yes its retro but IT WORKS!
    8 Speed is great and V-Brakes rock!
    Ex-wrench...have a Question just ask!
    I've rescanned for the cadence sensor and also have reset the sensor with the rubber button on the sensor itself. Same problem still exists. Very puzzling!
    Its missing your wheel sensor. The cad is picking up off the crank arm but the wheel magnet is not reading
    trail rat
    Reputation: slocaus's Avatar
    Quote Originally Posted by KINBOY
    Agreed. Happened to me when the wheel magnet got bumped with bike leaned against brush. When I repositioned the magnet and sensor, it worked.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    You are both right. Re-adjusted the wheel magnet and the symbol became static on the display. Thank you both very much!
