Results 1 to 14 of 14
    Feb 2007
    eTrex Bike Mount
    Is anyone using this mount for their eTrex? If so how do you like it?
    Reputation: 08HardRock's Avatar
    Looks like my Ram mount. If it is, it is great!! Easy enough to get the GPS in there, but once its in, its not going anywhere.
    Go about 3/4 down the page to see it installed: http://forums.mtbr.com/showthread.ph...35#post5517635
    Friends Don't Let Friends Drive
    2008 Specialized Hardrock Sport
    2010 Bottecchia RS290 Cross
    Reputation: MaxAug's Avatar
    I use this mount, very simple, light and stable:
    Blind biker
    Reputation: harry2110's Avatar
    Quote Originally Posted by MaxAug
    I use the same mount and it has survived an OTB without breaking it also look alot better than a RAM mount and is way cheaper. Also RAM mounts are heavy as they are mostly made of metal and thick plastic. I run them on my electronics in my bass boat and havent had anyone of them break yet so they are durable enough to withstand constant bumps and virbation, but at a weight cost.
    Oct 2007
    31.8 mm mount
    Does anyone know if this type of mount is available for 31.8mm bars?
    Reputation: MikeDee's Avatar
    Quote Originally Posted by stingray4100
    Yes, they are: http://www.maptown.com/23143
    Quote Originally Posted by harry2110
    Way cheaper? That mount is about $14-$15. I got my RAM for $16.
    Yes, the RAM is made of a thick plastic, but I think any weight difference would be negligible given the relatively small size of the mount; maybe an ounce or so difference. This particular model is only plastic.
    surly inbred
    Reputation: TroutBum's Avatar
    Quote Originally Posted by 08HardRock
    http://www.gpscity.com/item-garmin-e...mapbikemnt.htm
    Use the clip that comes with your Etrex unit to mate with this mount. Hard to go wrong for less than $4.
    Feb 2007
    Quote Originally Posted by TroutBum
    Thanks guys for all the reply and I did go with the Garmin brand mount. TroutBum, I wish you could've reply sooner cause I paid a little more than that, but its ok I'm glad I got the mount anyway.
    Track Day Addict
    Reputation: mkdive's Avatar
    I have the same mount.....works great! Have used it for a couple years now without any problems.
    I have a couple etrex's and now an Oregon 400t. I'm debating mounting the Oregon on my kona. Its a little bigger than the smaller etrex that Im used to.
    Quote Originally Posted by mkdive
    Never had a problem, even during hard freeriding or falling down on singletrack!
    My Etrex lives on a Kona too!
    Never had a problem with the Garmin mount for my Vista HcX and 60csX, both on MTB and on Race bike.
    Have a look at www.softplate.nl where you can find specialized GPS mounting solutions for bikes.
    Ron
    UBER Addict
    Reputation: gdotbat's Avatar
    Where can I get the little clip that screws into the GPS unit? I didnt get one with my Etrex Legend CX unit.
    UBER Addict
    Quote Originally Posted by gdotbat
    Nevermind, I found it.
    http://www.gpscity.com/item-garmin-e...etrexcclip.htm
