Results 1 to 2 of 2
    Semper Fi
    Edge Cadence on a C-Dale Rize?
    Anyone with a Rize found a good spot to get the cadence sensor on? I just can't seem to get it on there w/o interference from the cable.
    Reputation: giuliano's Avatar
    Apr 2005
    I am having the same exact issue and I can't get a good spot for the cadence/speed sensor to work. I am going to try installing right over where the brake line is held because it seems that will be the best spot to put it but I just need to find a way that the sensor can be hold pretty good to avoid it moving around. Like I said I try this tonight and I'll let you know if it worked.
