    New question here. edge 205 wheel size input
    simple question, can you or can't you input wheelsize for 205 ? Page 20 in manual shows a field for doing this but can't get it to show on mine ,
    Reputation: taterbug's Avatar
    Quote Originally Posted by spdplay
    Mine does not show that field. Since it does not work using wheel size, my guess is it is not on the unit
    thanks for the reply taterbug i assume it's not needed then and the 305 does because of more features......
    trail rat
    Reputation: slocaus's Avatar
    You cannot use the cadence / speed sensor pickup with the 205 (or a HRM), so it is not in the menu. The lack of cadence, HRM and barometric altimeter is what makes the 205 less expensive than the 305.
    The 605 also lacks those features compared to the 705.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
