Results 1 to 3 of 3
    Reputation: Okie Dokie's Avatar
    Difference between Forerunner 405 and 405cx?
    Can someone elaborate on exactly what the difference is between these two devices?
    I cannot seem to pick up what the difference is.
    thx
    Originally Posted by XC62701
    Agreed...make it longer. I want to know death is an option
    Wandering not Lost
    Reputation: BThor's Avatar
    www.garmin.com
    then do a comparison should be pretty simple such as this:
    https://buy.garmin.com/shop/compare....eProduct=11039
    Reputation: jkmacman's Avatar
    40 bux? i have the regular 405, the elevation don't work and can't use it in water. i bought the green one used,
    used it at a race last week end and the battery died in the final 4 minutes, i think i moved it the night before and the charger wasn't attached properly
    if you swim too check out garmin Forerunner 310XT GPS Enabled Sports Watch with Heart Rate Monitor by Garmin
    i swam this morning w/no hrm if i need one i take the cheap polar
    btw the edge 305 elevation is good for bike only w/accurate elevation
    Look to where the river ends, or where the river starts...
