Results 1 to 17 of 17
    Cool Garmin Mount
    I just saw this. I know its probably geared more towards road bikes, but still pretty cool!
    Above Category Cycling | Bar Fly Garmin Mount
    Reputation: Joe V's Avatar
    Jan 2011
    Nice, wonder if it will fit a 200?
    trail rat
    Reputation: slocaus's Avatar
    Even better than that.
    3T Cycling - INTEGRA
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Feb 2007
    Only for 325 dollars more! haha
    I been seeing the bar fly one, looks good, I might have to pick one up
    Berkeley Bicycle Club (BBC) - http://berkeleybike.org
    noob
    Reputation: trueblue01gt's Avatar
    what is wrong with mounting set up that comes with a garmin. i have no issues with it at all
    2007 Fisher Rig
    2011 Trek Paragon
    2013 Trek Madone 2.1
    trail rat
    Nothing. Some of us like to customize.
    since 4/10/2009
    Reputation: Harold's Avatar
    the integra is nice. but for the mtb, I do not like that mounting position "out there" in front of the bike. it exposes the GPS more and adds to the risk of breaking something in a crash. I think the on-the-stem location is ideal for the mtb, as it's quite protected by the bike in the event of a crash. With the Integra, I wouldn't be surprised if other stem companies began to introduce integrated stem mounts in other spots...and hopefully they include options for other models.
    But with that said, I do see the argument posed by the vendor in the OP, that the stem mount is less than ideal for viewing. I think that depends a lot on the stem being used, but I have found a need to play around with angles a bit with my GPS. thankfully that's not too difficult, even though using shims to adjust the angle a bit may not be the cleanest option.
    I wouldnt use it on my MTB either, and I never have an issue with being able to see my 500 now. I would however possibly get this for the road bike!
    It looks like a nice option, but the standard mount still works well for me, although it is a bit of a pain with the bars on my TT bike. I'm up to six bikes now, so I really wish Garmin would allow me to add more than 5 bikes to the profile.
    Reputation: Adim_X's Avatar
    I am switching to a shorter stem so now my edge 800 mount will not work. However I am not a fan of mounts like these. Have you guys seen any good diy spacers that people have used to raise the stem mount up some so it fits short stems?
    since 4/10/2009
    Quote Originally Posted by Adim_X View Post
    look at these threads:
    GPS/Computer/Light mount for tough situations
    Paul Components Stem Cap Light Mount for GPS
    still on the front page of this forum so all you'd have needed to do is look.
    Quote Originally Posted by NateHawk View Post
    I did look, and then I asked about DIY options you guys might of seen. These mounts look like crap and put my GPS in position that I do not like. I was curious if maybe there were some spacers that someone had dremeled to raise the stock garmin mount. Don't worry I won't ask any more questions in your gps forum and I will double check every thread before ever posting a simple question again.
    since 4/10/2009
    ease off there, good buddy. you did not reference that you were aware of the mounts I linked to. if you had, I wouldn't have bothered posting those links.
    super short or steeply angled stems are a big problem for GPS receivers. the only solutions I've seen are to mount to the handlebars or to the top tube.
    Sorry, work was making me testy and I took your post a little demeaning. I am gonna fab up something with some stem spacers. Will post a pic of what I am thinking.
    I want a professional looking mount extension that just raises the stock garmin mount. Essentially what I did here, so my garmin would mount to a shorter stem.
    trail rat
    They did wedges that lift for the old 305/705 mounts. I have several and use them to do exactly that. I have seen nothing similar for the new 500/800 mounts. You could get a block of plastic and a wood rasp and make something quick and easy. It would need longer O rings, but a good hardware store has those. DIY!
    Quote Originally Posted by slocaus View Post
    Today, I hacked up a bike tube and put layers under the mount. My mounts came with a bunch of o-rings and I had sizes long enough to fit. It did the trick, I just want to make it prettier. I got some ideas and some parts lying around. Was thinking grind on a red carbon stem spacer, and then glue a strip of tube to it to prevent slippage and basically wedge it in like i have the tube pieces above.
