Results 1 to 7 of 7
    Reputation: Hudnut's Avatar
    Apr 2005
    Chinese sensor compatibility
    Has anyone tried using one of those generic BTLE and ANT+ sensors on ebay? I'm wondering if my Year 10 Lezyne micro c GPS would recognise it.
    https://www.ebay.com/itm/CYCPLUS-BT-...kAAOSw7z1aKN43
    since 4/10/2009
    Reputation: Harold's Avatar
    BT is questionable. That protocol is probably present mostly for phones, anyway. Most bike computers that have BTLE don't use it for sensors, anyway.
    However, ANT+ is not. As I understand it, ANT+ protocol has more reliable compatibility between sensors and head units. If the protocol is present on both devices, then they should work together.
    loud hubs save lives
    Reputation: sennaster's Avatar
    I had two of these on a road bike for speed and cadence to use with a dumb trainer before getting a smart trainer
    https://rover.ebay.com/rover/0/0/0?m...2F222545619684
    They’ve worked fine. I’ve since moved them to be speed sensors on my bikes and have them paired with my garmin. They have BLE and Ant+. They can be speed or cadence.
    I had one unit that was dead on arrival, but the seller promptly sent me another.
    Apr 2005
    Quote Originally Posted by sennaster View Post
    I ordered one of these. I'll report back if it works with Lezyne y10.
    Quote Originally Posted by Hudnut View Post
    Should work without issues since you have ble and ant+
    I’d suggest manually setting the circumference of the wheel for the most accuracy once you get it paired
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Ive tried a few different chinese sensors. The sunding ones will connect, but constantly disconnect rendering them completely useless. Same problem with the BT003 speed can cadence sensor. However, I have a couple of CooSpo sensors that work great with the Lezyne Y10 GPS. None that Ive tried were the magnetless type. I actually have one from gearbest sitting in my garage somewhere, but I have yet to install it.
    Apr 2005
    I got everything hooked up via ANT+ without any issues. Did a short ride and did not record any drop out or disconnects. Quality seems decent enough.
  1. Replies: 0
    Last Post: 02-06-2015, 04:58 PM
  2. Replies: 1
    Last Post: 04-26-2014, 06:43 PM
  3. Replies: 11
    Last Post: 01-31-2013, 05:17 PM
  4. Garmin 305 Cadence Sensor Compatibility
    By gmgarcia in forum GPS, HRM and Bike Computer
    Last Post: 01-27-2012, 02:05 PM
  5. not just a chinese carbon frame, but 90% chinese!
    By menusk in forum Bike and Frame discussion
    Last Post: 06-22-2011, 01:53 PM
Members who have read this thread: 26
