Results 1 to 2 of 2
    CATEYE Vectra Wireless Cyclocomputer Circumference Setting
    I have a question regarding the circumference setting of my Cateye. I have a 2.25 front tire and the circumference settings according to the Cateye manual do not include a 2.25 size tire. It goes from 2.125 (207 cm) to 2.35 (208 cm). Was just going to use the 207 cm setting, but thought I would ask what others are doing. Just curious. Thanks.
    You can always measure around the wheel with a string and see what measurement you get. I'm running a 2.3 on the front and 2.1 on the rear and using 207. There is a way to set it up manually but i dont really understand the diagrams
    "If this doesn't work, my back-up plan is failure!"
