    Canondale Lefty and Computer Setting
    Hi Everyone -
    I have a Canondale F2 - Lefty and a Cateye Strada Wireless
    In addition i have the computer mount from Canondale - However since the sensor is mounted near the hub and not near the tire - the settings need to be different for the computer size measurement
    anyone have any suggestions
    rob
    Dec 2008
    The sensor placement doesn't matter as long as it detects the magnet.
    The sensor doesn't measure linear velocity, it measures angular velocity (that is, the amount of turns in a second, which is the same no matter where the sensor is located).
    BM and PQ Trail Rep
    Reputation: bankerboy's Avatar
    +1
    Most sensors measure the number of rotations in a given time. Since the hub will rotate the same amount of times as the tire, the location of the sensor is more personal choice or where ever it functions best.
    The world does not revolve around you but your actions impact us all!
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    Settings.
    The setting is in place to be able to allow for different tire sizes. If you want exact, measure distance of one FULL wheel rotation in mm. Then the cpu clicks off the # of hits, and multiplies by (x) mm.
    gfy
