    Calories dissapeared and temperature
    I did a search for this on this forum and could find an answer. I just purchased a garmin 800 and used it for the second time today. On the way out it showed calories burned, on the way back it showed 0 calories burned. When I uploaded it to connect it did show total calories. Why did it not show any calories on my edge on the way back?
    Also, is there a way to see what the outside temperature on the edge 800 is while riding?
    Reputation: plantdude's Avatar
    Not sure about the calorie thing, but for temp you just need to customize your data fields on the screen(s) through the training pages.
    Enjoy your new toy
    Ok thanks. I'll check it out.
    Oct 2011
    Sometimes I find my 800 data screens will get changed if I put it in my pocket without locking the screen. It seems that you'll get random screen touches that will put into screen edit mode and change things around. Might have been that the calories display or mode was changed. Might try looking at that display screen setting and see what is up.
