Results 1 to 2 of 2
Thread: cadence
    Feb 2006
    cadence
    How do you use the cadence function on a bike computer? You just try to keep it steady? To what rate?
    Ride More, Work Less
    Reputation: heyyall's Avatar
    There are a lot of articles on the web for cadence. Basically it is a number to look for a while, but once you get settled into your pedaling routine, you don't need to follow the numbers too closely on a ride. I've found a sweet spot around 90rpms. This gives enough room to pedal faster or slower as the terrain changes. That is, having a higher cadence seems to give you more reserve when there are quick changes in gradient that you can't adjust for with gears. Too low of a cadence (e.g., grinding out a long climb) does increase the force on your knees and it can cause some damage.
    Now, if you are a single speed, cadence doesn't matter except to help you get the gearing tied into the terrain.
    Here is the cadence profile from my (road bike) ride this morning. I had the garmin on the wrong bike setting, so it didn't detect the speed/cadence sensor. That shows how closely I watch the cadence on a ride
    Craigslist & MTBR --free ads for all
  1. Speed/Cadence sensor vs just GPS
    By dss8653 in forum GPS, HRM and Bike Computer
    Last Post: 08-17-2016, 05:32 PM
  2. Wireless Cadence
    By CoopermanGSA in forum GPS, HRM and Bike Computer
    Last Post: 03-30-2013, 06:52 AM
  3. Cadence
    By Bdabike in forum Beginner's Corner
    Last Post: 03-29-2013, 07:54 AM
  4. Is there an Ideal cadence for hills
    By jbl_91762 in forum Beginner's Corner
    Last Post: 07-25-2012, 11:00 AM
  5. Help a newb out with cadence question
    By KenInCa in forum Beginner's Corner
    Last Post: 03-07-2012, 11:20 PM
