    bike computer accuracy
    as I move the sensors down towards the center of the wheel is the computer less accurate? cannot get the 5 mm minimum spacing further up the wheels I have sigma BC 1106s on both bikes brand new wired types.
    high plains drifter
    Reputation: mateoway's Avatar
    Should'nt matter where on the spoke the magnet is it reads tire revolution so if your computer is set up correctly it should be accurate .Either use the size chart in the directions or make a mark on the tire and on the ground roll the tire a complete revolution
    and make a mark on the ground and measure the distance.
    Humble self-proclaimed nothing.
    On MTBR hiatus :(
    I like to get my sensor as close the the hub as possible. Closer to the rim and the magnet gets usually gets knocked around a little.
    As Mateo said, no change in accuracy. The sensor is only counting wheel revolutions.
    For best accuracy, when you measure your wheel roll-out, be use the tire is filled to your appropriate riding pressure, and that you simulate normal riding weight on that tire. Those two items have the biggest impact on accuracy of the mileage recorded.
    speedub.nate
    MTBR Hiatus UFN
    thanks for the info, much appreciated
