Results 1 to 6 of 6
    Belt clip for Edge 705
    Does anyone make a belt clip adapter for any of the Edge GPS? I find it would be easier to reach for on the belt then in the pocket when hiking. An arm band strap would be nice also.
    My other ride is your mom
    Reputation: Maadjurguer's Avatar
    you can just put it in a pocket...it works fine through the clothing...do it all the time BC skiing.
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    And why not use the stem/bar mount? Even easier to reach...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Quote Originally Posted by Dan Gerous
    That would be a little heavy on the stem, let alone embarassing to check on when hiking or jogging?
    LA CHÈVRE
    I see... I missed the word 'hiking' it seems...
    since 4/10/2009
    Reputation: Harold's Avatar
    It's intended as a bike specific GPS. There are better options for hiking, and that's how Garmin has positioned their products. Hence, if you want a belt clip...you will probably have to figure out how to make one yourself.
