Results 1 to 12 of 12
    Sep 2012
    accurate tire size set
    I have a tahoe 2.0 2012 & using a bike computer it's wheel size is :
    26*2.20
    54-559
    but the attached manual doesn't have this size what should I do ?
    Attached Thumbnails Attached Thumbnails accurate tire size set-scanimage001.jpg
    Trailhead Poseur
    Reputation: jjaguar's Avatar
    Oct 2011
    Measure rollout. Using the valve stem for reference, sit on the bike and ride in a straight line for one complete revolution of the wheel, then measure the distance between the start and finish points. For more accuracy, ride farther (two or three revolutions) and take an average.
    It's the most accurate method anyway, because actual tire circumference will vary depending on tire model, pressure, and bike and rider weight.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by peaceful1 View Post
    26*2.20
    54-559
    Do a roll out. Been discussed here many, Many, MANY times.
    mtbtires.com
    Sep 2012
    thanks guys for helping me out just fore making it clear
    when I find out the exact tire circumference what should I do with it?
    it suppose to make a special number in the chart right ?
    Feb 2006
    Enter it directly as wheel circumference after adjusting it to the correct measurement asked for (cm or mm).
    Dec 1998
    To quote your attached chart: "wheel circumference in mm"
    Clear enough?
    mtbtires.com
    Sep 2012
    hey! in the top it says "wheel circumference" why I haven't seen that before !
    by the way is the magnet placement important in the accuracy (answered)
    you guys are great I appreciate all the help
    Dec 1998
    Only in that the magnet needs to properly align with the sensor.
    mtbtires.com
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by shiggy View Post
    yup. that is all. the sensor is simply a reed switch that only ticks off revolutions. the computer head unit counts those revolutions and converts them to a distance using the wheel circumference.
    Sep 2012
    when I ruled out it was 2100 mm but when I calculated with its radius it was 2136 mm
    since 4/10/2009
    a proper rollout accounts for tire pressure and rider weight compressing the tire as you ride, while using the radius does not.
    Ride several revolutions and get an average.
    Put a zip tie around your wheel & tire so it marks the ground as you ride -- have also heard of people using a dot of paint.
  1. Replies: 16
    Last Post: 10-09-2012, 09:23 AM
  2. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum General Discussion
    Last Post: 02-21-2012, 05:50 PM
  3. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum Wheels and Tires
    Last Post: 01-26-2012, 12:54 AM
  4. 700x37 tire size what tube size?
    By noobie39 in forum Wheels and Tires
    Last Post: 07-11-2011, 04:01 PM
  5. Digital Tire Gauge Accurate at Low PSI?
    By onepivot in forum Fat bikes
    Last Post: 05-13-2011, 01:42 PM
