    Reputation: Zudnik's Avatar
    705 mount to stem
    How are ya'll attaching your 705 to your stem? Does it come with the mount, or are you fabbing something up? Any pics? Thx.
    she comes with 2 mounts.. 1 for mounting to a horizontal bar (handle bar) and the other for a vertical bar (stem).
    scroll down this page for a pic of the mount: http://www.letsgomobile.org/en/revie...ge-test/page2/
    Thanks Pathogen.
    trail rat
    Reputation: slocaus's Avatar
    Quote Originally Posted by pathogen
    And you can pull the bottom section off, turn it 90 degrees, and have two horizontal or two vertical.
    form the instructions:
    The Garmin Edge handlber mounts is compatible with all of Garmin Edge cycling computers and can be used to mount your Garmin Edge on the stem or handlebar.
    # To change between 0 degrees and 90 degrees, be sure to remove the zip ties first. Change the orientation of the two pieces and reinstall zip ties
    # Works for all Edge models including 205/305/605/705
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
