Results 1 to 3 of 3
    XTC Frame Needs Brake Booster?
    I am using a v-brake on the rear of my xtc frame.
    I feel the braking power is not strong, I wouldn't say weak.
    Someone said a brake booster e.g. salsa's one is necessary to reinforce the not-that-strong frame?
    Is that true? Will the stopping power be significantly increased?
    Powered by Pulvoron
    Reputation: dirt diggler's Avatar
    yes.. notice the flex on the frame when you actuate the v-brakes ? the brake post actually rotates outward. because of the forces. booster connect the the post and decreases the forces and concentrates to the pad and rim. nashbar has a set of carbon booster cheap amd search on ebay. the salsa is on the heavy side.
    good luck
    dirt diggler
    I would make sure everything else is set up correctly before I added one of those. I ran that frame with Deore and XT V brakes and never noticed the flex. I had strong (for V brakes) braking and the only squealing issues I had were from the XT V brakes, which I didn't spend that mush time dialing in. I'd check pads and rims for contamination, good cable length, and clean housings first.
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. xtc frame vs ranier frame
    By Mr. VT in forum Giant
    Last Post: 03-28-2004, 11:54 AM
  3. 80/100mm fork on XTC frame?
    By frank4 in forum Giant
    Last Post: 03-27-2004, 03:31 PM
  4. Ti brake studs on a Ti frame?
    By tmaybee in forum Weight Weenies
    Last Post: 03-16-2004, 05:20 AM
  5. Removing brake bosses: void frame warranty?
    By SilverStar in forum General Discussion
    Last Post: 02-17-2004, 08:05 PM
