Results 1 to 3 of 3
    XTC composite 29er headset problem
    I have a 2012 XTC composite 29er that I've been riding for the past 2 years and the headset has developed a clunk. I've replaced the cartridge sealed bearings so far and greased the cups liberally but it didn't fix the problem. The Lower aluminum bearing cup is very tight in the frame, but the top cup easily comes out and I believe the play is due to this. Is there a shim available to keep the top cup tighter in the frame? I hope I didn't slightly ovalize the top of the head tube. Any thoughts?
    Mar 2011
    I'd try wrapping the top cup in some Teflon pipe tape, might snug it up a bit. Don't go too thick tho cause it may damage the frame.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    I believe this is a drop in head set and shouldn't be that tight. It shouldn't clunk either though. IME that is a frame issue. Make sure it doesn't have a small crack in that area.
    I'm a mountain bike guide in southwest Utah
  1. XTC Composite 29er Thread
    By GnarBrahWyo in forum Giant
    Last Post: 10-31-2016, 02:35 PM
  2. Giant xtc composite 29er 0 or 1?
    By Moto752 in forum 29er Bikes
    Last Post: 05-07-2014, 05:57 AM
  3. damaged 29er xtc composite
    By Daverhea in forum 29er Bikes
    Last Post: 01-08-2014, 09:00 PM
  4. 2012 XTC 29er Composite
    By thedarkknight in forum Giant
    Last Post: 09-30-2012, 09:19 PM
  5. Replies: 0
    Last Post: 05-09-2011, 04:58 PM
