Results 1 to 5 of 5
    XTC 2 '04 or '03
    I can get a '03 XTC 2 for around $850 or a '04 for around $1050 and having trouble. Frame is nearly the same but change in fork from Skareb to Duke U-turn. Some have reported the Skareb fork breaking bad. Should I go for the new set-up or save a few bucks and try to get LBS to change out fork? Also still looking hard to GF Big Sur and Spec. Stump Jump.,, Looking for good hardtail with ability to do entry level racing one day. Thanks for any input.
    Reputation: wannabeRacer's Avatar
    Quote Originally Posted by Mtnsheep
    Just looked into GIANT web site, and 04 is better than 03 in terms of parts (few) but it's really up to you?
    Can you afford $1050? If it was me, I would go for the 2004. Its the same animal (bike) just different parts (name) and the ride might be different to Duke fork than Skareb.
    cheers
    Get your freak on!
    Quote Originally Posted by wannabeRacer
    cheers
    Might sound weird, but I'd say get the 03.... the skareb is a better race fork hands down..... and if you do manage to break it, then it should be warrantied and possibly upgraded for free!
    BTW, if you do get the 03, just keep a eye on the reverse arch as that is where most of the breakages happened.
    Either way, you will be very happy no matter what you choose
    I have the 03
    and from what I read, the difference in parts is basically going from titec to easton aluminum (seat post, handle, stem). me being a novice, its negligible. I like the skareb comp, no problems, fully adjustable. I personally would go for the 03 and save the cash. I have not had a single problem with mine, doing XC racing or just long XC rides. I also like the black frame.
    thanks for input
    thanks for everyones input, going to do some more test riding this weekend.
  1. 03 or 04 Brain? Should I be suspicious?
    By Odie in forum Specialized
    Last Post: 06-06-2004, 11:19 AM
  2. 03 vs 04 S works Epic frames
    By WOY in forum Specialized
    Last Post: 04-13-2004, 12:37 PM
  3. '03 Specailized Epic or '04 Stumpjumper Comp?
    By Theadict in forum Bike and Frame discussion
    Last Post: 03-30-2004, 12:48 AM
  4. '03 vs. '04 Iron Horse Hollowpoints, Changes
    By Speedub.Nate in forum Bike and Frame discussion
    Last Post: 03-22-2004, 11:02 AM
  5. could 03 stamped be 04 forks?
    By greenchops in forum Shocks and Suspension
    Last Post: 03-17-2004, 06:13 PM
