Results 1 to 5 of 5
    Will a 130mm fork be OK on the Giant XTC hardtail?
    Hello
    I'm looking to get a hardtail frame. I'm looking at the Giant XTC frame.
    Has anyone built one with a 130mm fork? Will the geometry be OK?
    I want to put a Fox Talas on it. I could reduce the travel to 90mm for long climbs.
    Do you think this frame is suitable for the 130mm Talas?
    the usual 'cons' go with such a longtravel fork:
    *slackened headtube angle = less responsive steering
    *altered riding posture: good or bad
    *altered stresses through headset/headtube: negligible
    probably not ideal. it's a big change from the standard 80mm. i suppose you have to ask yourself 'why' you're wanting such a long fork, and maybe the frame/bike is not suitable for your needs (freeride/urban?).
    i currently have an 85mm REBA on mine, and it suits my riding style/XC. feedback generally suggests 100mm is about as long as you want in order to retain performance.
    - Giant NRS Composite - Giant XTC2 - Giant TCRCzero - Giant OCR1 -
    - nothing stock here - move right along now -
    - Geelong area, Australia -
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    No engineer or frame expert but common sense tells me that 130 on that frame is too much.
    Call Giant first
    The headtube may not be able to handle the stress that a 130mm fork will put on it and may crack. Call Giant if this size fork is advisable but my guess is that the frame is not designed to handle it.
    Quote Originally Posted by Arrazo
    yeah, you keep reading about this - hence my reference to it in my post - but i must say i don't buy into too much.
    i mean, what sorta quality frame is not going to be over-engineered and not tolerate a slackening in the headtube angle? and how much difference or added stress does that provide compared with a normal setup with a 250lbs rider or someone doing 3~5ft drop-offs? you would expect the frame to handle these sorta things pretty well without falling apart, so i would have though a 'long' fork wouldn't impact that much.
    not ranting, just curious.
