Widest tire on 2012 Trance X2
What's the widest tire i can go on my 2012 trance x2? It currently has 2.25 nobby nic's. can i run 2.4 or 2.5's?
Living Ghetto Fabulous!
Just throwing this out there;
The Schwalbe 2.5 sized tires that I've seen are HUGE. I've really only seen Muddy Marys in that size. It might fit the frame, but you could have clearance problems with your chain/front derailleur when using the granny ring. (Unless you're 1X10)
Good luck!
 Originally Posted by kidwoo
The internet sounds like a tough place to ride.
UC makes a good point - not all tires at "X-size" are the same. You're more likely to get info if you post up what tires you're *specifically* looking to put on your Trance.
thanks guys
nevegals. would 2,5 work up front and 2.35 in the rear?
- You may not post replies
- You may not edit your posts
Forum Rules
