Results 1 to 5 of 5
Thread: Wheel Squeak
    gdv
    gdv is offline
    Wheel Squeak
    Hi all,
    I have new Anthem X1 29er and ever since I got it has had an annoying repetitive squeak coming from the front wheel. It's a little chirp, chirp, chirp that speeds up as the wheel spins faster. It does it with brakes on or off, pedalling or coasting, even while walking and pushing the bike along if enough pressure is put on the front end. If front wheel is lifted it goes away.
    I figure it must have something to do with the front hub or thru-axle? I'm to this type of wheel and QR15, any ideas on how to fix this?
    Thanks,
    gdv
    gdv is offline
    Figured it out... It was the valve stem of all things! Put a nut on it and the annoying squeak is gone.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Interesting, I always throw the valve nuts away.
    DFMBA.org
    Reputation: MTBeing's Avatar
    Wheel Squeak
    Lightly grease your thru-axle if you haven't done so.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    gdv
    gdv is offline
    Quote Originally Posted by DiRt DeViL View Post
    I do too. Must be a weird tube/rim combination thing.
  1. Misterious squeak.
    By Millfox in forum Brake Time
    Last Post: 08-06-2012, 11:43 AM
  2. xtr M985 squeak
    By cldymnky in forum Brake Time
    Last Post: 12-03-2011, 10:15 PM
  3. Front wheel squeak
    By jaycastlerock in forum Specialized
    Last Post: 08-14-2011, 01:46 PM
  4. EX 8 Squeak
    By building_miracles in forum Trek
    Last Post: 07-13-2011, 06:17 PM
  5. Fox Float 130 RL squeak
    By jfwebber in forum Shocks and Suspension
    Last Post: 06-01-2011, 05:18 AM
