Results 1 to 3 of 3
    Quiet Professional
    Reputation: chef7734's Avatar
    What would be cheaper? Change components?
    Ok so I am still planning on getting a giant reign x but wondering what the best option is. I know I was a 2x10 and a coil over shock. If this year is like last year would it be cheaper and more advisable to the the x2 and upgrade to a 2x10 setup or get a x1 and change out the shock to coil over? Thats saying if this years x1 is only a single ring on the crank.
    Apr 2005
    Before you put too much thought into it, check on availability in your size. A lot of the Reign X's are sold out for 2012.
    Quiet Professional
    It will most likely be a 2013 and not sure the specs of the x2.
