Results 1 to 5 of 5
    Bike Whore
    VT bottom bracket question
    What spindle width should I spec out for my VT frame?
    I want to run an XT (octallink design) crankset. I was wondering if the VT just took a conventional 113mm or need a wider 118-ish size spindle.
    Thanks in advance.
    I run a 113mm with my Truvativ set, but the cranks specs call for a 113BB. So you'll have to check which the cranks call out for.
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    68x113
    Aug 2005
    Makes no difference vis * vis the frame.
    If you had an LX chainset you'd need a 121. Depends on the crankset, as mentioned previously.
    Bike Whore
    Thanks everyone for the input.
    I ended up going with a new outboard BB design, the Evolve XC version.
