Results 1 to 2 of 2
    Apr 2005
    Travel On 120mm Manitou Minute 1 - OEM On Giant VT1
    Hi, does anybody know whether it's possible to increase the travel on a set of 2005 Minute 1 forks from the manufacturer (Giant) restricted 120mm to the full 130mm available on aftermarket forks?
    Failing that, it is possible to buy stiffer springs in the 120mm setting?
    Thanks guys.
    PS, also posted on the shocks thread.
    IMBA Canada
    The compression legs are 10mm shorter and the crown assembly is the same lenght as the Black 120mm. So no, you can't get a longer travel without buying a new fork. You can get springs without any problems! The springs from the Black fork will fit with no problems
