Results 1 to 5 of 5
    Trance2 rear shock help
    Hi I have a 2008 trance2 Im upgrading the rear shock on it and I noticed that the bottom bolt is like a sleeve bolt, which is a little bit bigger diameter than the hole on the new rear shock. Im putting a Rock Shox Ario 3.2, it has a metal bushing in the bottom of the shock, could I take that out or is there a different bolt setup I can get? Added a link to a picture that may help show what Im talking about..
    in Reading, Pennsylvania, United States - photo by rummie - Pinkbike
    Thank you
    Added a link to a photo of what Im talking about..maybe itll help...
    Inspector Gadget
    Reputation: abeckstead's Avatar
    Feb 2012
    Yeah press the bushing out. You can do it with a large C clamp and some sockets if you don't have a vise or press.
    I hope you have a big trunk... cause I'm gonna put my bike in it!
    thhank you. ill try that.
    Fits on the bolt, just need to fix the spacers, as the shock width is a little wider..
  1. 100mm rear shock to 200mm shock??
    By WSRebel in forum Shocks and Suspension
    Last Post: 08-02-2013, 07:46 PM
  2. Rear Shock setup - rear wheel skipping
    By ThePunisher in forum Downhill - Freeride
    Last Post: 02-14-2013, 07:19 PM
  3. Replies: 4
    Last Post: 08-22-2011, 04:30 AM
  4. Two problems. Rear derailer, rear shock
    By Petti the Yeti in forum Tooltime
    Last Post: 07-03-2011, 08:14 AM
  5. Replies: 5
    Last Post: 06-09-2011, 09:16 PM
