    May 2005
    Trance x1 rp2 plus and minus
    Is it just me or is the minus setting on my Trance X1 way too plush? On anything but a severe fast downhill it seems useless. I've had rp3's on other bikes and there was never such a huge difference in the settings???
    Reputation: EGF168's Avatar
    It comes set with a very firm ProPedal setting so there is a much more noticeable difference than some other bikes when you switch it from normal to ProPedal but so long as you have the right air pressure in the shock it shouldn’t be too plush in the normal setting.
    Quote Originally Posted by EGF168
    Can you change this without buying new parts?
    Reputation: ggnarl's Avatar
    your maestro suspension just works better than other designs. Ive never heard of a complaint about too plush. Unless you need to raise your air pressure.
