Results 1 to 18 of 18
    Reputation: Forged's Avatar
    Trance X - ProPedal Compression Tune Question
    I bought my 2008 Trance X1 frame new from a dude on Craigslist. The rear shock is an Fox RP2 with the lowest rebound tune (shortest bar) and the highest compression tune (longest bar). The suspension is very firm when the shock lever is in ProPedal mode, likely a result of the high degree of compression tune. From pics of Trance-Xs I have seen, other Trance Xs appear to have RP2s with the middle compression tune (middle bar) and not the high compression tune (maybe my frame was originally ordered custom with the firmest compression tune). If you have an RP2 on your Trance-X, what compression tune do you have and how do you like it? Like I said, mine is very firm making it a very efficient climber but not that compliant over roots and rocks and such.
    i think most trance x's should come with a medium compression tune. i am getting mine soon and will check for you
    Most Trance X riders only use propedal on the road and fire road climbs. On trails the bike works so damn good with the shock open there is no need for propedal.
    Johny Sokko!
    Reputation: Stoner's Avatar
    Second, Formula 33's post
    Oct 2007
    propedal is for putting around parking lots.. its really not even necessary for climbing fire roads unless you want to stand and mash up them for some reason. the bike will do everything better with the shock ran open.
    Reputation: antonio's Avatar
    Jan 2005
    My RP2 has a middle compression tune. As stated, I use it on extended fireroad sections . . . sometimes.
    Sounds like the middle compression tune is standard
    Thanks all for your feedback. Agreed, the bike climbs very well with the propedal off - better than my racer-x did. I am most curious as to how the compression setting is spec'd on individual X's as I did not buy mine from a shop. Is the propedal option a "user" option, or do you simply get what you get - some firm; some middle.
    Might be a dumb question but how do you figure out what your RP2 is tuned to? Is there a label or marking on it identifying the tune settings?
    Jun 2005
    Quote Originally Posted by Forged
    RP2 = propedal on or off
    RP23 = propedal on or off (with 3 levels of propedal adjustment when on)
    Reputation: kobayashi's Avatar
    Quote Originally Posted by tdotrider
    Yes. You may find it on the right side of the shock.
    ahh thank you, I hadn't taken a close enough look at the shock...
    just checked and apparently it has a medium rebound tune and medium compression tune
    Quote Originally Posted by jdc5r
    You're lucky
    Mine has med rebound tune and hard compression tune...
    Looks like the "stock" rebound and compression tune setting on Trance-X RP2s are all over the map...curious. I suppose this is good for prospective buyers to be aware of as it may allow them to order a new frame with the propedal settings most appropriate for their style of riding. As to how one would determine "what's best", I have no idea. Middle/Middle sounds reasonable. My high/low setting seems very efficient - maybe a good race oriented setting.
    Could the shock's tune level be related to the frame size?
    Possibly...I am riding a small TX-1. This though occurred to me too, but my understanding is that the rear triangle, and shock mounts positions are standard throughout sizes such that the leverage ratios, etc remain consistent throughout the sizes as well. Perhaps Giant makes assumptions regarding the correlation between frame size and rider weight and specs the different frame sizes accordingly. If that were the case, I would expect the smaller sizes to have lower compression and rebound tunes than the larger frame sizes. As my small frame has the highest compression tune, the application of my theory appears to fail.
    ooops, made mistake there. I've got the same settings as Forged has. Sorry fellas, my bad..
    Jan 2005
    The settings do seem to be all over the place.
    I have the mid compression tune, and the low rebound tune, on a medium frame.
    If the Maestro suspension design is truly a dw_Link copy, then supposedly these frames would work best with the lower tune in both the rebound and compression.
