Page 82 of 90 FirstFirst ... 32 72 78 79 80 81 82 83 84 85 86 ... LastLast
Results 2,026 to 2,050 of 2250
  1. #2026
    Jan 2013
    Hey Everyone,
    Here is my 2012 Trance X1. I have done a number of mods. To date they are: float 140mm, haven bar, haven carbon wheels, DMR vault pedals, reverb. Loving it and am doing BC bike race with my wife this year so hopefully everything holds up!
    Here is my wife's bike, 2013 Trance X1 29'er, stock except we replaced the stock brakes with new XT's!
  2. #2027
    I miss f88
    Reputation: laxman2001's Avatar
    Quote Originally Posted by StraightDrop View Post
    I'm pretty interested in doing this. I ride on one ring 99.99% of the time. Pros? Cons?
    Cons?
    Well .01% of the time you'll wish you had the other rings!
    But seriously 1x is fine, the only thing you need to worry about is chain retention. I tried to make my buddy's MRP 1x fit when I went without much luck (that guide has some serious design flaws IMO), but eventually just used the front derailleur and reminded myself not to shift. Not Ideal, I know. But it worked OK and I liked 1x9 OK. Went back to 2x9 when I moved to a place that deserved a granny ring.
    The pros, of course, are lighter weight, more simplicity, and maaaybe marginally better shifting in the rear (since you're always in the middle ring and there's less chain slack for the derailleur to take up)
    WHEEEEEEEEEEEEE!!!!
    ------__o
    ----_`\<,_
    ---(_)/ (_)
  3. #2028
    Reputation: slimphatty's Avatar
    2011 Giant Trance X3 with some upgrades. Currently getting the Giant Contact dropper post repaired.
    Attached Thumbnails Attached Thumbnails Trance X Pics Thread...-imag1199.jpg
  4. #2029
    hi everyone, does somebody here have trance x and trance x29? what about the difference? im using trance x 26 right now but im curious which one is better...
  5. #2030
    Mar 2013
    Quote Originally Posted by slimphatty View Post
    That, is a good looking bike. White linkage and cables look good on this. Also looks a little choppered out, nice.
  6. #2031
    May 2013
    2011 Trance X4:Rockshox Pike 454 Dual Air U-Turn w/ 20mm thru axle
    Mavic XM719 Rims on Switch Evo Hubs
    Superstar Nano Tech Pedals
    Raceface Respond 740mm bar
    Superstar Zenith Am 65mm Stem.
    Maybe a new rear shock in the future......
  7. #2032
    Oct 2012
    This is my 2012 Trance X. Kind of totally customized.
    Replaced the Float Fork to a 110-130-150mm Talas(a few weeks ago I sent it in because there was a cracking noise in the crown section and the connection between stanchions and crown was defect, so they swapped the whole unit to Kashima stanchions)
    - Fox Float RP2
    - Shimano XT Crank
    - Shimano XT Pedals
    - Shimano XT Derailleur
    - Giant Contact Switch Dropper Seatpost
    - Syntace Superforce 75mm stem
    - Veltec AM One Wheelset
    Overall weight 12,9kg
  8. #2033
    Apr 2013
    Giant Trance X 29
    Trance X Pics Thread...-giant-trance-cm.jpgTrance X Pics Thread...-giant-trance-2-cm.jpg
    Now that the weather has cleared up i have been able to put some time in on the new bike.
    All said and done she's weighing in at 25 pounds 11 ounces.
    Amazing bike, and after demo'ing/riding many 29ers and new 650b's I have no regrets.
    Built kit includes:
    Full XX1 groupset w/ 32 tooth front sproket
    Mavic Wheels
    Easton XC70 carbon post
    Fizik Tundra saddle
    Fox Talas CTD 140
    Race face Turbine stem and SixC bars
    Working on what pedals to go with now.
    I new that she would descend well but was pleasantly surprised at how well it climbs. The XX1 is quiet and smooth but needs some getting used to when climbing (requires steady momentum and cadence, especially on longer climbs).
    All in all an amazing set up and glad I built it as is.
  9. #2034
    knobby noob
    Reputation: axl886's Avatar
    Oct 2012
    It's me again.
    Just replaced the big ring with a 32t Raceface bashguard and installed blingy DMR Vaults. Running tubeless Hans Dampf too...
    2014 Yeti SB-66AC
    2015 Canyon Torque DHX
    2016 Transition Smuggler
  10. #2035
    Reputation: kobayashi's Avatar
    My longtime favorite - 2008 Trance X1. Amazing bike.
  11. #2036
    Reputation: parkp81's Avatar
    Here is the most recent picture of my Trance X1. Disregard the background stuff, did not really prepare for a photoshoot.
  12. #2037
    wheelie king
    Reputation: 661lee's Avatar
    New tires and Renthal Fatbar Lites 10mm.
  13. #2038
    Hard as nails
    Reputation: Dirtman's Avatar
    The Replacements...
    I will play. I recently cracked my 05 VT and was provided this as a replacement. Needless to say, I am very very PLEASED!
    [SIZE="4"]Thank God men cannot fly, and lay waste the sky as well as the earth.
    Henry David Thoreau[/SIZE]
  14. #2039
    Reputation: chadalex78's Avatar
    Oct 2011
    What bottom bracket and chain ring you runnin?! Wanna set mine up like that baaaaaaaad!
  15. #2040
    Hard as nails
    The bottom bracket is a bb30 with the Xt cranks. It's a race face (32t)chainring that I picked up at jensonusa I believe.
  16. #2041
    Oct 2011
    Quote Originally Posted by Dirtman View Post
    So its the original BB? Press fit? Trying to figure out how to make mine like that without spemding a fortune on E13 BB or something like that... I have a 2011 x2 and just took the big ring off and replaced with bash and NEVER use the granny... Would dig gettin rid of the front DR.
  17. #2042
    Hard as nails
    Check out the mrp x1 seat post mount. I picked up a single unramped chain ring and placed in middle position because I have a triple ring crankset. Did not have to use any spacers (included) and set up was extremely simple. The guide cost about $99 but look around and do price match it saved my $15.
    Good luck bro
  18. #2043
    Hard as nails
    Btw. You van use your current middle ring to save money. The mrp should set you back approx 85-90 bucks.
  19. #2044
    Jun 2013
    Hi I have a giant trance xo and I would love to make these upgrades! Would be much appreciated if you could tell me what size shock you fitted? I read in the owners manuals that the float shock that it comes with is 7.25in. I can't seem to find a coil one that size so am wondering how you got yours?
    And what kind stem you are running because I've been looking every where for a short stem?
    thanks
  20. #2045
    Reputation: bassman1441's Avatar
    I just put a 50 mm raceface atlas stem on my '09 x3 to replace the stock 100mm. Feels so much more controlled now in combo with my 785mm bars. I'm 6' and riding a medium but I like the feel of a more compact bike.
    I'll be posting pics soon seeing as this is the trace x pic. thread.
  21. #2046
    Jun 2013
    Quote Originally Posted by clever username View Post
    Here's my ever so slightly modified 2011 x1, the main changes are the elka stage 5 shock and 150mm talas.
    What size shock did you fit onto this? and stem
  22. #2047
    Jun 2013
    yeah Im 6' myself but I made the mistake of going with what the guy at the shop said and buying a large frame. They didnt have the bike in the shop so thought they'd know best, but WRONG. I love a smaller size myself, easier to throw around and more confidence inspiring. I paid way too much for it so im going to keep it and just do what you've done to yours.
    Back to that stem, the reason I asked is because of the OD2 that giant has going and wasn't sure what after market ones would fit
  23. #2048
    Jun 2013
    What size shock is on this?
  24. #2049
    Jun 2013
    Quote Originally Posted by Uncle Cliffy View Post
    2 full seasons on this thing, and I'm going for number 3...
    FRAME= Giant Trance X Advanced SL size XL
    FORK= Rock Shox Revelation RLT Ti 2 position 20mm axle
    CHAINRING= Ethirteen 35t
    CHAINGUIDE= MRP Lopes
    STEM= Easton Havoc 35 50mm
    HANDLEBAR= Easton Havoc 35 carbon
    HEADSET= Cane Creek Angleset 1.5deg. cup (HA=66 with 13.25 BB.)
    CRANKSET= Shimano XTR M980
    BOTTOM BRACKET= Shimano XTR
    BRAKES= Shimano XTR Trail
    TIRES= Maxxis EXOs (DHF 3c front, HR2 60a rear)
    PEDALS= Twenty6 Prerunners
    SEATPOST= Rockshox Reverb
    SADDLE WTB= Silverado SLT
    GRIPS= ODI Troy Lee
    CASSETTE= Sram XX 11-36
    WHEELSET= Easton Carbon Havens
    SHIFTER= Shimano XTR
    REAR DERAILLEUR= Shimano XTR M980 med. cage
    CHAIN= Shimano HG-X 10 speed
    Vital honored the forum nerd in me today with this:
    What size shock?
  25. #2050
    Mar 2013
    custom built trance x 2013.
    handle bar: EASTON HAVEN Havoc 740mm
    stem: giant am Contact 50mm
    Grip: lizard skin
    brake: Shimano XT
    Shifter RH shimano XTR
    CRANKSET: Shimano XT with 34T e. thirteen
    Chain guide: E.thirteen
    Rear Mech: Shimano XTR Shadow+
    Cassette: Shimano XT 10 speed 11-36T
    Pedals: Shimano XT Trail
    WheelSet: giant
    Tires: Maxxis Ardent 2.25 Tubeless
    Chain: KMC
    Saddle: Prologo Scratch.
    Seat Post: Giant
